Lawson86 Posted May 1, 2021 Share Posted May 1, 2021 Hi guys, Just wondering if someone can help me got a 2012 focus 1lt ecoboost. Brought the car not going head cracked no compression. Got recon engine from a firm I've used a few times in the past with no problems but engine turns firs up runs for 2 to 3 seconds and dies as if it runs out of petrol. Not getting any codes up on forscan, I am getting petrol to the high pressure fuel pump. Anyone got any ideas as what could be wrong Thanks for your help Patrick Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 1, 2021 Share Posted May 1, 2021 Are you getting a decent flow rate from the tank pump? Does sound like the most likely culprit. Can you keep it going if you press the throttle? Quote Link to comment Share on other sites More sharing options...
Lawson86 Posted May 1, 2021 Author Share Posted May 1, 2021 Getting a good flow from tank when I take the quick release off on the line the flow hits the scuttle panel. To start the car the throttle has to be open or it just stays turning Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 1, 2021 Share Posted May 1, 2021 Does sound like a fuel pressure issue then. Can you read requested Vs actual fuel pressure on Forscan with these? Also do you know what was done on the recon? Just wondering if it might have been timed wrong. Quote Link to comment Share on other sites More sharing options...
Lawson86 Posted May 1, 2021 Author Share Posted May 1, 2021 Ya I think it is too. Not sure how to do that with Forscan but I know I can do it on launch my old man has that at the moment I'm going to pick it up this evening. Do you know roughly what pressure it should be looking for? The engine had new head and new bearings and both belts fitted I put my timing pin into it to make sure the timing was correct while it was on the floor. Quote Link to comment Share on other sites More sharing options...
Lawson86 Posted May 1, 2021 Author Share Posted May 1, 2021 I've only just started using Forscan traditional I used launch Quote Link to comment Share on other sites More sharing options...
Lawson86 Posted May 4, 2021 Author Share Posted May 4, 2021 Hi guys, just a quick update got the car going after a long day I found my problem was a small crack in a vacuum hose. Which was opening when the engine was running. Hopefully this post might help some else in the future 1 Quote Link to comment Share on other sites More sharing options...
