2012 Ford Focus Keeps running up to 30 minutes after engine is turned off and key is removed from the ignition
Everything turns off ok on the car as if normal but the engine stays on. I have to stall the car to turn it off and if the start stop decides to work you think it's off and start to walk away and it turn itself on  again?  This morning the battery was completely dead after just having it tested and saying it was perfect.
That's a weird one!
Faulty Start/Stop (Ignition) switch?
Has the car been "messed" about with, e.g using Forscan?
If so, return all modules back to ASbuilt and see if that cures it.
Failing that, you may have a fault in the BCM
  Only 75 emoji are allowed.
  • Create New...
Forums
News
Membership
