gibbo1471 Posted May 9, 2021 Share Posted May 9, 2021 Hi mk3 focus 2015 estate after hopefully finding where water is getting in if I remove the 2 bolts in the picture will this then allow me to move the bracket out from that position or will the strut expand more I want to clean it behind reseal then retighten etc with silicone behind it I am also going to put ptfe tape on the bolts as that must be where the water is getting in also do these have a rubber seal behind? Quote Link to comment Share on other sites More sharing options...
Ski Stick Posted May 10, 2021 Share Posted May 10, 2021 Hi Simon Removed driver side strut this morning trying to track a leak. Easy enough task, but prop tailgate because the remaining strut cannot hold the weight. I removed all 4 bolts so I could take strut to workbench for cleaning. A very thin rubberised gasket was stuck to the surface and in poor condition. It is just possible that it had started life as a sealant rather than a gasket. Having cleaned up the surfaces. I applied a generous coat of Screwfix No Nonsense clear sealer and reassembled. Need some rain now to see if problem fixed, but I am optimistic..... Nigel Quote Link to comment Share on other sites More sharing options...
gibbo1471 Posted May 11, 2021 Author Share Posted May 11, 2021 I only had 2 bolts on mine as per picture what car year and model do you have or a photo of the bracket you took off thank you Quote Link to comment Share on other sites More sharing options...
Ski Stick Posted May 12, 2021 Share Posted May 12, 2021 2014 tdci estate. Sorry to confuse, I took the full strut off- 2 screws on body (as per your photo) and two on the tailgate. Unfortunately, this was not the source of the leak.... Tomorrow I will remove the side trim and try to identify the leak as I sit in boot whilst someone plays a hose pipe over the area. If successful, ,I'll post again with photos. Quote Link to comment Share on other sites More sharing options...
F0CUE Posted May 12, 2021 Share Posted May 12, 2021 I would check the wiring loom rubber center of the tailgate. 1 Quote Link to comment Share on other sites More sharing options...
gibbo1471 Posted May 13, 2021 Author Share Posted May 13, 2021 Ski stick they rang me today saying it is coming in from the roof rails the silver ones so I will update once beeen told more Quote Link to comment Share on other sites More sharing options...
ScaniaPBman Posted May 14, 2021 Share Posted May 14, 2021 There's a lot of good advice in this post Come back after you have read it with any questions. ScaniaPBman Quote Link to comment Share on other sites More sharing options...
gibbo1471 Posted May 14, 2021 Author Share Posted May 14, 2021 Most of this is for hatchback cars Quote Link to comment Share on other sites More sharing options...
ScaniaPBman Posted May 15, 2021 Share Posted May 15, 2021 Well, I can give you advice based on my experiences with leaks on a hatchback but have never had an estate. I stripped out the plastic rails on outside of the roof panel and sealed up the groove beneath. I also removed the rear bumper and sealed up the vents there, but since your leak source is from above this level then this may not help you any. Hopefully someone who has an estate will be along to give you direct advice. ScaniaPBman. Quote Link to comment Share on other sites More sharing options...
Ski Stick Posted May 15, 2021 Share Posted May 15, 2021 Thanks for everyone's input on this. I think I have now fixed my leak and this is how. First, the estate air vents seem to be lower than the standard hatchback and won't cause water ingress even if they are loose. Anyone know differently? I checked all of the grommets into the body and these seemed ok (Thanks Focue). I then stripped out the off side boot boot liners, plastic trim until I could see all of the metal of the body. The water was coming into the boot from the seam in photo 1, which is the tailgate pillar, but still needed to find out where it was getting in. Photo 2 shows the roof of the car with tail gate open. You can see the rear end of the roof rail. Playing water over this area only, the water began to drip inside the car. There is factory sealant around this area of where the body panels meet, and -on my focus- a very definite "split" or wider gap just where the roof drops away from the roof rail. I re-sealed at photo 2 and the water is no longer coming in. But, never say never...I may have simply changed where the water flow goes! And I'd be very interested to hear how to remove /seal the roof rail fixings. For now, I will start putting the car back together. Incidentally, I had considered that the water may be coming through the roof rail mounting but ruled it out as the roof lining wasn't wet or marked. But I maybe wrong on that - time will tell. Nigel 2 Quote Link to comment Share on other sites More sharing options...
gibbo1471 Posted May 20, 2021 Author Share Posted May 20, 2021 Hi Nigel I got my car back they siliconed under the running roof rails on the top they said they stripped the roof lining down to check the leak I imagine they bolt down but only accessible with roof lining down 🤷♂️ They also siliconed where the seams are on pic 2 under the black rail rubber it doesn’t seem to be leaking at moment I also went one step more as per my photo I removed the boot strut mounting and cleaned the bracket on the back and the paint area it sat then put some silicone where the bracket bolts down especially around the top of the bracket as when I removed it there was some old sealant on it so I did that and also a fibre washer on both ends of the bolt I’ll keep you informed I have owned all 4 estate versions mk1,2,2.5 and never had issues just shows how rubbish they are put together now 😡😡 Quote Link to comment Share on other sites More sharing options...
Ski Stick Posted May 23, 2021 Share Posted May 23, 2021 Hi Simon, Seems like a good result. The fibre washers are a good idea- wish I had thought of that. But, the boot is still dry so fingers crossed as I really don't want to drop down the roof lining. I'll keep my eye on it and will post again if I have to remove the rails. Oddly enough, there appears to be an access to the rear rail bolts on the lining but on opening the hinged cover, I couldn't see any fixings. But that would be too easy.... Quote Link to comment Share on other sites More sharing options...
CraigT Posted November 11, 2021 Share Posted November 11, 2021 (edited) Thanks for everyone's input on this. I think I have now fixed my leak and this is how. I re-sealed at photo 2 and the water is no longer coming in. But, never say never... time will tell. Nigel Hi Nigel. Did this fix your issue? I am having a similar issue, it's definitely coming in high up, but not wetting the roof lining. I see it running down from the metal join you pointed out and also a bit further up. I suspect it is coming from the back section of the roof rail/trim and that I may need to take the rail off 😨 , but no-one seems to have any guide for doing this on a mk3 estate. Thanks for the post and the pictures confirming the location of the source. Craig Edited November 11, 2021 by CraigT Add more photos Quote Link to comment Share on other sites More sharing options...
ElCani Posted November 12, 2021 Share Posted November 12, 2021 This probably isn't going to help with this specific leak, but I thought I'd post it here (from another thread) in case it helps someone else with a leaking MK3 estate. Mine first leaked from some crappy stickers behind the bumper, and then later via water coming under the boot aperture seal in the bottom left corner. Quote Link to comment Share on other sites More sharing options...
Ski Stick Posted November 26, 2021 Share Posted November 26, 2021 Just seen this is still active. Craig T, in answer to your question, yes, my simple fix stopped all water ingress. From memory, I used Screwfix "No Nonsense" clear sealer which seems to work well in all manner of projects. I'm glad I did not have to remove roof bars- it looks too much of a pain, although if needs must.... Good luck everyone and I hope this helps. N Quote Link to comment Share on other sites More sharing options...
