Ford focus mk2.5 rear interior light mod
Hi everyone I am thinking of doing a rear interior light mod what cable to use I no I got two have 2 with 2 core  cable to run to the back so it can connect up to 3 pins but I just want to make shore I use the right cable for the job thanks all
Twin Core 15Amp 12V DC Cable 4 Metres Required.
Hi thanks for your reply but it a rear interior light cos it so dark in the back seat area and taking my son out it hard work lol so I need to put a light in the back cheers
I just bought this light for the back and it got the plugs with it too just need to sort out the wiring for it
Ok thank you for your help focue
Hi guys I just done the cutting of the roof lining just waiting on my plugs for the back of the rear interior light I am fitting and then I will run the wiring though the back hole to the front will update when done and take a few photos
Did this to mine couple of years ago, also wired in some vanity lights under the sun visors.
No photo description available.
I had some spare 10 amp cable I think it was so just used that.
I think the interior light at the back is just a single 5w bulb. If I remember correctly to calculate amps its `amps = watts/volts` so 5/12 = 0.4A
So as long as the cable you choose can handle that load you will be fine. Obviously if you run more lights such as the vanity lights like I did it will up the load you put through the wiring.
Thanks for that I did read up on amp and Watts.  so I found one slightly bigger then the original car wiring cos the original wiring is 0.35 so I ordered 0.5 which holds 11 amp so it will be  plenty for a 5watt bulb this is the cable I ordered in the picture below hope this will help other people too
Hi Steve on the back of the rear light it as 2 pin and a 1 pin is this right the 2 are positive and the one is negative so I need to run 3 wire though to main light then many thanks
Yup three wires, one permanent live, the other for when you open doors etc and the final is ground.
From memory i believe its the same as the front light so i just extended each wire and wired it in to the same input on the secondary light.
EDIT: Oh and dot't forget to properly glue the wires down or do something to manage vibrations or you may hear them rattle.
That's great advice thanks you
