richardc1983 Posted May 10, 2021 Share Posted May 10, 2021 Anyone had the following fault code before on a 1.6 tdci - P1261 Cylinder 1 High to Low Side Short? Engine shuddering like a bus and in limp mode since driving home on the motorway. Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted May 11, 2021 Share Posted May 11, 2021 Injector fail by the sounds of it Quote Link to comment Share on other sites More sharing options...
Steevo25 Posted May 15, 2021 Share Posted May 15, 2021 This is definitely an injector fault. Just had one go on mine. Exact same symptoms except my DTC was cylinder 3. The injector is around £200. Garage charged me just over an hour labour for diagnostic and then fit. Can easily be fitted yourself. Quote Link to comment Share on other sites More sharing options...
unofix Posted May 15, 2021 Share Posted May 15, 2021 If you do change the injector yourself, and no reason why not. Just remember that you will need to put the new calibration figure in using ForScan. Quote Link to comment Share on other sites More sharing options...
