Petti1971 Posted May 20, 2021 Share Posted May 20, 2021 Bought 18plate ecoboost 1 litre engine takes about 15 minutes to get up to temp but when I turn blowers on it drops and when turn off goes back up to normal is this normal as taken to garage they say it’s fine checked thermostat that’s all fine and coolant flowing fine they say it’s normal for the ecoboost engines Quote Link to comment Share on other sites More sharing options...
Midgeman Posted May 20, 2021 Share Posted May 20, 2021 When you say the temperature drops when you turn on the blower do you mean the cabin temperature or the gauge on the instrument cluster? I have a 1.0ltr Ecoboost and it does take longer to warm up than previous Ford's that I have owned. Quote Link to comment Share on other sites More sharing options...
Guy Heaton Posted May 20, 2021 Share Posted May 20, 2021 Engine temp should not dip significantly if you put the blowers on. Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted May 20, 2021 Share Posted May 20, 2021 1 hour ago, Petti1971 said: Bought 18plate ecoboost 1 litre engine takes about 15 minutes to get up to temp but when I turn blowers on it drops and when turn off goes back up to normal is this normal as taken to garage they say it’s fine checked thermostat that’s all fine and coolant flowing fine they say it’s normal for the ecoboost engines Doesn't sound right to me. We have a 2017 1.0 Auto and it warms up very quick (The heater does anyway) and the gauge is constant at middle point, no matter what you do. 1 Quote Link to comment Share on other sites More sharing options...
Petti1971 Posted May 20, 2021 Author Share Posted May 20, 2021 Temp on the gauge garage says that’s normal Quote Link to comment Share on other sites More sharing options...
Petti1971 Posted May 20, 2021 Author Share Posted May 20, 2021 Ford garage says that’s normal for temp to go down when blowers on sure to the ecoboost boost engine blowers work fine car was look at at and they say everything as it should be if there was a fault the light would come on when blowers are off goes bk to normal Quote Link to comment Share on other sites More sharing options...
Guy Heaton Posted May 20, 2021 Share Posted May 20, 2021 Yeah the garage is talking complete ***** frankly. Go somewhere else. A dicky thermostat for instance would not cause a fault light. We have a 1.0 ecoboost fiesta and a 1.5 economist focus and they are both up to temp in 5 minutes. 2 Quote Link to comment Share on other sites More sharing options...
Petti1971 Posted May 20, 2021 Author Share Posted May 20, 2021 Yes been to another garage there saying same as Ford it’s normal he looked at it and everything is fine he says thermostat is opening and closing as it should perfectly flow of coolant Quote Link to comment Share on other sites More sharing options...
unofix Posted May 20, 2021 Share Posted May 20, 2021 Hi Petti1971, if the car is working fine and the engine is not overheating then why worry about the temp gauge dropping a little when you put the heater on ? Just think if you had one of the many cars that don't even have a temprature guage you wouldn't even know that the temp changed when you switch on the heater blower. Quote Link to comment Share on other sites More sharing options...
iantt Posted May 20, 2021 Share Posted May 20, 2021 Ecoboost are efficient of sorts and therefore less heat generated so can take a while to get to temp. The gauge bears pretty much no correlation to temp increase from cold. When I had a focus ecoboost the temp gauge went from cold to normal ( via pcm signal) at around 40-50c after 4-5 mins but the thermostat temp required to open would take 12- 15 mins driving. All quite normal. 1 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted May 21, 2021 Share Posted May 21, 2021 8 hours ago, Petti1971 said: Yes been to another garage there saying same as Ford it’s normal he looked at it and everything is fine he says thermostat is opening and closing as it should perfectly flow of coolant Did they check both thermostats? The 1.0 ECOboost has a multistage cooling system with 2 thermostats. It is not uncommon for one of the thermostats to fail on a 1.0 ECOboost. A failed thermostat directly affects engine temperature and if the engine does not reach normal operating temperature it will also affect fuel economy. 1 Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted May 21, 2021 Share Posted May 21, 2021 Perhaps the car needs software updates maybe?? Quote Link to comment Share on other sites More sharing options...
mjt Posted May 21, 2021 Share Posted May 21, 2021 11 hours ago, iantt said: Ecoboost are efficient of sorts and therefore less heat generated so can take a while to get to temp Don't the Ecoboosts run hotter than normal petrols which is the cause of cracking of the reservoir? Quote Link to comment Share on other sites More sharing options...
iantt Posted May 21, 2021 Share Posted May 21, 2021 2 hours ago, mjt said: Don't the Ecoboosts run hotter than normal petrols which is the cause of cracking of the reservoir? yes they do but to get to temp can take longer than other engines. 2 Quote Link to comment Share on other sites More sharing options...
Guy Heaton Posted May 21, 2021 Share Posted May 21, 2021 The only time I've ever seen the temp gauge move quicker than the normal slow move to the middle is when my thermostat was broken. Quote Link to comment Share on other sites More sharing options...
Maverick Su-35 Posted January 3, 2022 Share Posted January 3, 2022 On 5/20/2021 at 4:43 PM, Guy Heaton said: Engine temp should not dip significantly if you put the blowers on. Guys, it's a very low consumption engine, with about 0.4 to 0.5L/h, compared to almost 1 liter an hour at idle of other vehicles. Proportionally the heat that the engine creates. So it makes sense if you put the blower to max rpm and full warm, that you'll eventually cool the engine by some 20 degrees C, remaining at just above 70 instead of 90, especially if it's cold outside and your anti-freeze mix is also with more water (which cools a lot better than the anti-freeze) than normal in the mix. These all count. Quote Link to comment Share on other sites More sharing options...
unofix Posted January 3, 2022 Share Posted January 3, 2022 Hello again @Maverick Su-35, there is almost no point in replying to any post that has been totally dead for more than a couple of months. This thread dates back to May 2021, which as it happens is the last time the OP visited. They didn't respond on thank anyone back then so your words of wisdom are falling on deaf ears. 2 Quote Link to comment Share on other sites More sharing options...
Alexis94040 Posted January 3, 2022 Share Posted January 3, 2022 On 5/20/2021 at 2:50 PM, Petti1971 said: Bought 18plate ecoboost 1 litre engine takes about 15 minutes to get up to temp but when I turn blowers on it drops and when turn off goes back up to normal is this normal as taken to garage they say it’s fine checked thermostat that’s all fine and coolant flowing fine they say it’s normal for the ecoboost engines Good evening Petti! Have a nice new year with health and anything good for you i wish to happen!!! Is your region reaches low temperatures? Here in Greece with the rare low temps my diesel ecoblue 1,5 in a morning with 3-4º celsious comes to normal temp after a very long time. If i use my blower as soon as i start the engine, temp rises even slower. To be honest, when it is cold outside in the mornings, i drive it loke having an egg on the gas pedal!!! I think that you are not going to have a serious problem with that issue. I wish the best for your car! Be well!!! Quote Link to comment Share on other sites More sharing options...
unofix Posted January 3, 2022 Share Posted January 3, 2022 @Alexis94040 this is a very old post. Petti has not visited here since 21 May 2021 Quote Link to comment Share on other sites More sharing options...
Alexis94040 Posted January 3, 2022 Share Posted January 3, 2022 Just now, unofix said: @Alexis94040 this is a very old post. Petti has not visited here since 21 May 2021 I haven't checked that at all i am very sorry! 1 Quote Link to comment Share on other sites More sharing options...
