Promocol Posted May 27, 2021 Share Posted May 27, 2021 Hi, just to ask if changing the water pump is something that an amateur like myself can replace over a weekend or is it a little involved? Also am I correct in saying that my 1.8 has a timing chain not belt? Quote Link to comment Share on other sites More sharing options...
mjt Posted May 28, 2021 Share Posted May 28, 2021 Haynes gives the job 4 out of 5 spanners for difficulty. Amongst other things it says the aircon compressor belt needs to be cut off and renewed using a special tool (that's included with the kit I think). If you haven't got a manual I'd recommend getting, or borrowing, one to judge for yourself. You are correct, the 1.8HE engine has a timing chain. Quote Link to comment Share on other sites More sharing options...
Promocol Posted May 28, 2021 Author Share Posted May 28, 2021 Thank you for your reply, on what you you have mentioned I think I will leave it to an expert🙂 Quote Link to comment Share on other sites More sharing options...
