Rear passenger window on 2007 CC3 won’t go back up
Hi, any advice is much appreciated as I adore my CC3 and have taken good care of it.
The passenger rear window won’t go back up. I don’t know enough to gauge if it’s safe to try to manually lift it up without doing any damage and can’t find anything on YouTube that’s been on any use - any thoughts?
Ford have quoted £472.00 for a new regulator + labour on top which is not possible any time soon!
Do NOT try to move the window manually, it will cause damage to the gearing/motor.
Have they tested and confirmed the window regulator is at fault or is that just their guess?
Hi, thanks for replying. It was a guess over the phone after explaining the issue - do you think it could be something else?
There are lots of possible problems, and most cost a lot less.
(a) faulty window switch
(b) blown fuse
(c) window stuck
(d) faulty relay
(e) faulty motor
(f) broken gearing on window lift
(g) window regulator/control fault
I would get an auto electrician to take a look at it first.
(b) blown fuse
(c) window stuck
(d) faulty relay
(e) faulty motor
Ok I’ll do that, thanks for taking the time to reply.
