Ranger wildtrak 65 egr cooler
Hi all,
I have a 2015 UK wildtrak that has a long history of issues that I believe relate to the egr cooler.
A couple of independent mechanics have historically diagnosed coolant loss as defective filler cap or bottle.
Both have been replaced but I still lose coolant so heres my logic.
- no visible destination of coolant (no puddles!)
- no oil in the water or water in the oil (not head gasket)
As such I assume the egr cooler is leaking into the exhaust.
Other symptoms
- periodic coolant loss (at least 2 litres per week)
- periodic engine cut out (as if overheating)
So, I'm banking on the egr cooler as such my question is as follows.
On a 2015 wildtrak can the egr cooler be replaced without dropping the gearbox?
I have no issue removing ancillary parts such as throttle bodies l, hoses and pipes but if it requires the transmission out the way or the engine lifted I will bounce it to ford!
Thanks in advance
Dan
  • 2 years later...
hiu
did you get to the bottom of this problem ?
who knows ? Dan hasn't visited the forum since 4th July 2021.
