Focus mk2 passenger headlight doesn't turn on if already in ignition
Hello guys!
I've recently got a Focus mk2 with bi-xenon headlight. My problem is, my passenger headlight (the other works fine) wont turn on if the ignition is already on. So basically i have to stop the car (key to ignition off), turn on the headlights, ignition on, start the engine again.
Should i replace the xenon igniter or something else could be the problem?
I'm pretty sure the plugs are the same for the headlight housing on the LHS and RHS, so try removing removing lights and swapping them over temporarily to see if the fault stays on the passenger side.
If the fault does move then you can put them back and start swapping ballasts etc.
