EnterTheEcho Posted June 21, 2021 Share Posted June 21, 2021 My power steering fliud is leaking out right where the hose goes into the pump (a common issue from my research). My local garage want over £1000 for a new hose and pump!! The car has got over 135,000mi on it so I am thinking about either using some high temp silicone sealent and hoping for the best. Would I have any issues with that, or just letting the pump die and not having power steering? Quote Link to comment Share on other sites More sharing options...
StephenFord Posted June 21, 2021 Share Posted June 21, 2021 1 hour ago, EnterTheEcho said: My power steering fliud is leaking out right where the hose goes into the pump (a common issue from my research). My local garage want over £1000 for a new hose and pump!! In a previous car (not a Focus) I had a new pump supplied & fitted for £140, that does seem an awful steep price, probably similar value as the car! Quote Link to comment Share on other sites More sharing options...
unofix Posted June 21, 2021 Share Posted June 21, 2021 Power steering pump for your model is about £75.00 plus fitting at a local garage - say 2 hours. Total job should be less than £250 1 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted June 21, 2021 Share Posted June 21, 2021 34 minutes ago, unofix said: Total job should be less than £250 Now you're talking, that £1000 did sound like a prize rip off! Quote Link to comment Share on other sites More sharing options...
EnterTheEcho Posted June 21, 2021 Author Share Posted June 21, 2021 1 hour ago, StephenFord said: Now you're talking, that £1000 did sound like a prize rip off! They really did wanna take me for a chump! Talked to a couple other garages if I cant get a decent price I will probably just part it out and use the money to get a newer focus lol Quote Link to comment Share on other sites More sharing options...
iantt Posted June 21, 2021 Share Posted June 21, 2021 Why does the pump need changing? Normally only the hose and union required. Easy enough job. Only an hour max to do. Quote Link to comment Share on other sites More sharing options...
ScaniaPBman Posted June 22, 2021 Share Posted June 22, 2021 When you say " the hose goes into the pump " that means to me the hose from the power steering pump reservoir down to the inlet to the pump its self. This is a low pressure item and easy to change. When it leaks the drip is from the pump body and can confuse the unwary. This twisty soft hose is about £30 and if you cannot fit it your self, will not cost much to fit at your friendly garage. Try this first before you scrap your car. ScaniaPBman. Quote Link to comment Share on other sites More sharing options...
