wires broke in fitting
hi
Ford Focus 1.5 echoboost 2015 i got engine light on, under the bonnet the wires out of this fitting were just dangling,so i removed fitting and stripped it down the wires in the pin connectors i connot remove, so is it possible to buy new connectors if so what is the size i need
They're common ford connector terminals, just cut a length of wire off a donor Ford in a scrappy and re-wire.
You could open the ends and clamp new wire in (or solder) but you'd have to get it dead right or the terminals won't go back through the connector
