Greenfaldo Posted July 30, 2021 Share Posted July 30, 2021 Morning all, my boys focus 1.6 on 61 plate keeps cutting out and wondered if anyone had any ideas. So when the car is idling it literally just cuts out, starts straight away. No lights up cheers Quote Link to comment Share on other sites More sharing options...
Bongo2296 Posted July 30, 2021 Share Posted July 30, 2021 My 61 plate 1.6 TI-VCT did this a lot. Some research here suggested a PCM update, completely fixed the issue and the car is so much more powerful now too. Quote Link to comment Share on other sites More sharing options...
Greenfaldo Posted July 30, 2021 Author Share Posted July 30, 2021 What’s a pcm update? Quote Link to comment Share on other sites More sharing options...
Bongo2296 Posted July 30, 2021 Share Posted July 30, 2021 A software update for your cars PCM. Needs to be done at a Ford dealer, cost me about £80. Unless anyone else has any other ideas, that would be my suggestion having had that exact problem myself. 1 Quote Link to comment Share on other sites More sharing options...
Greenfaldo Posted July 30, 2021 Author Share Posted July 30, 2021 3 minutes ago, Bongo2296 said: A software update for your cars PCM. Needs to be done at a Ford dealer, cost me about £80. Unless anyone else has any other ideas, that would be my suggestion having had that exact problem myself. Sorry for my ignorance just wondering if it’s the same as an ECU? Quote Link to comment Share on other sites More sharing options...
Greenfaldo Posted July 30, 2021 Author Share Posted July 30, 2021 Power control module???? Quote Link to comment Share on other sites More sharing options...
mjt Posted July 30, 2021 Share Posted July 30, 2021 Powertrain Control Module, and yes it's the same as an ECU. 1 Quote Link to comment Share on other sites More sharing options...
Greenfaldo Posted July 30, 2021 Author Share Posted July 30, 2021 9 hours ago, Bongo2296 said: A software update for your cars PCM. Needs to be done at a Ford dealer, cost me about £80. Unless anyone else has any other ideas, that would be my suggestion having had that exact problem myself. Sorry for my ignorance just wondering if it’s the same as an ECU? Quote Link to comment Share on other sites More sharing options...
Greenfaldo Posted July 30, 2021 Author Share Posted July 30, 2021 I suppose that Mr Ford wouldn’t possibly have it in and do as they were asked and upgrade the PCM but would want to plug it in and see for themselves what was going on with it. Quote Link to comment Share on other sites More sharing options...
Bongo2296 Posted July 30, 2021 Share Posted July 30, 2021 I had mine in at TCH Derby, they did want me to pay for a diagnosis as you say, but after some persuasion and a disclaimer that if it didn't fix the problem they weren't liable they did it for me. Probably the same at most dealers. Quote Link to comment Share on other sites More sharing options...
F0CUE Posted July 30, 2021 Share Posted July 30, 2021 Is it the 125 or 100? The 100 is duratec/sigma plain and the 125 is ti-vct. If it's tci-vct follow the above info. If it's the 100ps check the pipes for any splits a common pipe to split is the crankcase breather hose which connects the the pcv valve it's starts from the alternator end and goes in behind the intake plugging into the pcv. Quote Link to comment Share on other sites More sharing options...
Greenfaldo Posted July 31, 2021 Author Share Posted July 31, 2021 23 hours ago, Bongo2296 said: A software update for your cars PCM. Needs to be done at a Ford dealer, cost me about £80. Unless anyone else has any other ideas, that would be my suggestion having had that exact problem myself. Sorry for my ignorance just wondering if it’s the same as an ECU? Quote Link to comment Share on other sites More sharing options...
Greenfaldo Posted July 31, 2021 Author Share Posted July 31, 2021 It’s being plugged in on Tuesday to see if any codes come up, also looking at the MAF sensor, last night had a quick look in the dark and although not 100% that t it looked in great condition but without knowing to much about them it’s difficult to know if it’s ok or not. 1 thing I did notice is it’s a 6 pin sensor but one of the wires out of the connector is either capped or has been cut? It was the white wire, can anyone confirm if this correct? I couldn’t see the cable from the engine that would have gone to it if it had been cut. Quote Link to comment Share on other sites More sharing options...
Greenfaldo Posted August 1, 2021 Author Share Posted August 1, 2021 Been having a look at the MAF, not done anything to it if yet but when we looked at it has anyone else got the white cable out the top not attached?? Don’t think it’s been cut almost as if it’s capped. We have a 1.6 petrol on a 61 plate. Quote Link to comment Share on other sites More sharing options...
Greenfaldo Posted August 1, 2021 Author Share Posted August 1, 2021 Quote Link to comment Share on other sites More sharing options...
Greenfaldo Posted August 3, 2021 Author Share Posted August 3, 2021 Well I’ve cleaned the MAF sensor but it’s done exactly the same. Ford weren’t interested in just doing the pcm upgrade without it being plugged in first. Quote Link to comment Share on other sites More sharing options...
