TomsFocus Posted August 3, 2021 Share Posted August 3, 2021 I've just found out these exist! Has anyone got one? https://vevor.co.uk/products/5ton-electric-jack-lift-car-impact-wrench-air-compressor-set-3-in-1? Seem to be plenty of options, various kits etc. Would ned to be as light as possible for me, but also strong enough to do the job safely. Slightly confused by the one above containing a belt cutter/screen hammer...that'll be really useful stored in a case in the boot! Quote Link to comment Share on other sites More sharing options...
unofix Posted August 3, 2021 Share Posted August 3, 2021 Oh ! I like the look of that 👍 are you going to get one ? I need to buy a little air compressor just to blow my tyres up now and then but I could be tempted to buy this instead. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted August 3, 2021 Author Share Posted August 3, 2021 1 minute ago, unofix said: Oh ! I like the look of that 👍 are you going to get one ? I need to buy a little air compressor just to blow my tyres up now and then but I could be tempted to buy this instead. Definitely tempted by one yeah. Though something smaller and lighter than that particular one. I bought a battery tyre compressor a few months ago. Works well but not cheap. It was on a lightening deal at around £25 when I bought it. Spent the last decade using Sainsburys free PFS forecourt compressor but they started charging this year! ACPURI Car Tyre Pump - Portable Tyre Inflator Air Compressor USB Rechargeable with Digital LCD Display, 6000mAh Battery, LED Light for Car Tires, Bicycle, Motorcycle, Balls, Swim Rings : Amazon.co.uk: Automotive 1 Quote Link to comment Share on other sites More sharing options...
eddie eastwood Posted August 3, 2021 Share Posted August 3, 2021 Lots on eBay at different lift tonages. https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1311&_nkw=electric+car+jack&_sacat=0 2 Quote Link to comment Share on other sites More sharing options...
williamweb Posted August 3, 2021 Share Posted August 3, 2021 1 hour ago, TomsFocus said: Definitely tempted by one yeah. Though something smaller and lighter than that particular one. I bought a battery tyre compressor a few months ago. Works well but not cheap. It was on a lightening deal at around £25 when I bought it. Spent the last decade using Sainsburys free PFS forecourt compressor but they started charging this year! ACPURI Car Tyre Pump - Portable Tyre Inflator Air Compressor USB Rechargeable with Digital LCD Display, 6000mAh Battery, LED Light for Car Tires, Bicycle, Motorcycle, Balls, Swim Rings : Amazon.co.uk: Automotive Free air at Sainsbury’s down here.👍 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted August 3, 2021 Author Share Posted August 3, 2021 21 minutes ago, williamweb said: Free air at Sainsbury’s down here.👍 Make the most of it then. I reckon they're all being changed to paying machines. 1 Quote Link to comment Share on other sites More sharing options...
williamweb Posted August 3, 2021 Share Posted August 3, 2021 12 minutes ago, TomsFocus said: Make the most of it then. I reckon they're all being changed to paying machines. Interesting, normally I put 32 psi all round in.I’ll have to start putting 64 psi in so that it lasts longer.What do you reckon?😀 3 Quote Link to comment Share on other sites More sharing options...
unofix Posted August 3, 2021 Share Posted August 3, 2021 2 hours ago, TomsFocus said: Spent the last decade using Sainsburys free PFS forecourt compressor but they started charging this year! Yes my local Tesco have now had the Air Line fitted with a 'Pay by Card' at 50 pence for a couple of minutes. Now the problem is once you have used your card the time starts ticking away, but they have thought of that and if you need more time you just press a button and it automatically charges another 50 pence and gives you a couple more minuets. The big problem I see is that unless you wait for it to time out and switch off, then the next person to use the machine can simply press to extend the time if its still running and it will happily just charge another 50 pence to your card. In fact you could end up paying for everyones air so long as the machine is kept running. Maybe fitting a Stop button would be a good idea ? 1 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted August 3, 2021 Author Share Posted August 3, 2021 3 minutes ago, unofix said: Yes my local Tesco have now had the Air Line fitted with a 'Pay by Card' at 50 pence for a couple of minutes. Now the problem is once you have used your card the time starts ticking away, but they have thought of that and if you need more time you just press a button and it automatically charges another 50 pence and gives you a couple more minuets. The big problem I see is that unless you wait for it to time out and switch off, then the next person to use the machine can simply press to extend the time if its still running and it will happily just charge another 50 pence to your card. In fact you could end up paying for everyones air so long as the machine is kept running. Maybe fitting a Stop button would be a good idea ? I didn't have my wallet at the time so didn't take any notice of how it worked. That does seem like a pretty big flaw in the system though! Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 24, 2022 Author Share Posted April 24, 2022 **Update** Just wondering if anyone got one of those electric jacks? And if they're reliable? Also - does anyone have any clever ideas about lifting a wheel to remove/refit with a lot less physical exertion than the the normal way? I've got a battery impact gun for bolts, and can always add extra leverage to spanners etc, but the effort needed to jack up and remove the wheel is an immediate barrier for me at the moment. Spent the last few months trying to find a mobile mechanic to do the job instead, but there aren't any around here! Local garage have quoted £100 to do the job, which I would have paid, but as the car is undriveable, would have to spend another £50-100 on a car transporter first, with the extra hassle that entails as well. If I can work out a way to do it myself, that would be preferable. Quote Link to comment Share on other sites More sharing options...
Turvey Posted April 24, 2022 Share Posted April 24, 2022 Car wheel dollies might do the job but seems a bit of a waste buying 2 if you only need 1 for 1 job https://www.sgs-engineering.com/wd2000-450kg-wheel-dollies Electric jacks? I've not seen one in action but read this review and see if it helps https://bestreviews.com/automotive/jacks/best-electric-car-jacks Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 24, 2022 Author Share Posted April 24, 2022 28 minutes ago, Turvey said: Car wheel dollies might do the job but seems a bit of a waste buying 2 if you only need 1 for 1 job https://www.sgs-engineering.com/wd2000-450kg-wheel-dollies Electric jacks? I've not seen one in action but read this review and see if it helps https://bestreviews.com/automotive/jacks/best-electric-car-jacks Thanks Kevin. Wheel dollies don't help with lifting/lowering/aligning the wheel unfortunately. I can roll a wheel once it's on the ground. It's moving it the 2" between the hub and the ground that's the problem. Frustrating when something seemingly so small makes the rest of the job impossible. Quote Link to comment Share on other sites More sharing options...
Turvey Posted April 24, 2022 Share Posted April 24, 2022 Dolly with rollers? But then they're more expensive making it more uneconomical! Tough one 🤔 hopefully someone will come up with an answer 🤞 Times like this that one appreciates their own mobility etc that they take for granted and maybe also appreciate the struggle that others go through doing what may seem a simple task. 3 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted April 24, 2022 Share Posted April 24, 2022 2 hours ago, TomsFocus said: Thanks Kevin. Wheel dollies don't help with lifting/lowering/aligning the wheel unfortunately. I can roll a wheel once it's on the ground. It's moving it the 2" between the hub and the ground that's the problem. Frustrating when something seemingly so small makes the rest of the job impossible. I may have missed it, but couldn't find anyone suggesting an 'air jack'? 1st saw one used in USA in te 70s an they've always impressed me, though I expect you'd need to use it very frequently to make it economically viable. One of the companies I found doesn't even list the price, I hate that! But assume it's out of reach for most amateurs! https://www.selson.com/shop/#page-content Oh, I love the link you provided in your initial post, the company showing an attractive young girl in high heels using it to prove that stupid old men like me might be in with a chance of using it too LOL 1 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 24, 2022 Author Share Posted April 24, 2022 Must admit, I hadn't seen an air jack before! Does look very cool and should be quick, but too expensive for home use as you say. Also can't see a failsafe on them? If a motor fails, a scissor jack would remain raised. If an airbag pops...does the car just come crashing down? I've seen plenty of cars blow bags on air ride...would hope these are heavier duty, but still not sure I'd trust it! 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 2, 2022 Author Share Posted May 2, 2022 Just ordered one of these for £66.50. Dekaim Electric Car Jack, 3T 12V Lifting Floor Scissor Jack with Electric Impact Wrench The same basic 12v jack unit seems to be used across the cheaper kits. Wasn't sure whether to go for this with the impact wrench as well. Only a pound difference, but obviously more weight and a larger case to store. Decided I would, just in case I do get to a position where I can drive regularly again and lift a wheel up to the boot. The impact gun might be useful if I got a flat while away from home in that instance. 1 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted May 2, 2022 Share Posted May 2, 2022 3 minutes ago, TomsFocus said: Just ordered one of these for £66.50. Well, from the description, looks pretty easy to use LOL "man or lady could deal with the issue of the vehicles..." Look forward to your review when you use it. 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 6, 2022 Author Share Posted May 6, 2022 Well, getting the twin kit might have been a mistake... It's much heavier than I thought! Shipping label states 9kg, which is just a bit less than a standard alloy & tyre for reference. Oddly, I didn't consider that effectively fitting a starter motor to a scissor jack would add so much weight lol! Will get it opened over the weekend and see if the items are more manageable individually. 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 18, 2022 Author Share Posted May 18, 2022 So, two weeks on and this is still sealed in its delivery packaging... The heat is now exacerbating my vertigo. If anyone local can swap the swap the caliper on the Golf for me, or knows anyone that can, please let me know via PM. Will pay of course. Just want the car driveable so I can try to practice in the car park before deciding whether it's worth MOT'ing or not. Obviously no point if I won't be using it on the road for a while. 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 2, 2023 Author Share Posted April 2, 2023 **UPDATE April 2023** Well, it's been a long time coming but I finally used the electric jack today. Works very well. The jack itself is a little heavier than the standard scissor jack, but not all the much more when it's out of the box. Just plugged into the 12v lighter socket to use, although it also comes with croc clips to use directly from battery if required. Plenty of cable to reach the rears and it seems surprisingly well built. I'm a bit concerned about how much battery charge it uses, but as the car is at home and I have the GB40 jump starter, I'm not really bothered by that. Would probably suggest leaving the engine running if using as a roadside emergency. 3 Quote Link to comment Share on other sites More sharing options...
unofix Posted April 2, 2023 Share Posted April 2, 2023 15 minutes ago, TomsFocus said: Just plugged into the 12v lighter socket to use, although it also comes with croc clips to use directly from battery if required. Plenty of cable to reach the rears and it seems surprisingly well built. Good to know it works. Although I'm afraid that @StephenFord will be extremely disappointed with you for not posting photos of it in use 🤣 3 Quote Link to comment Share on other sites More sharing options...
Jimpster Posted April 2, 2023 Share Posted April 2, 2023 checked the date on this before reading 🤣 2 Quote Link to comment Share on other sites More sharing options...
alanfp Posted April 2, 2023 Share Posted April 2, 2023 If it uses its rated 15A for even 4 minutes that's approx 1 Ah (hold on - it's EXACTLY 1 Ah ) so I don't think you have to worry about batt capacity. I'd be more concerned about pulling 15 A through the cig lighter socket which I always thought were 10A capacity. It'll probably be OK though and you'll soon know if it blows the fuse. 1 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 2, 2023 Author Share Posted April 2, 2023 battery is flat... But it was already on its last legs anyway. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 2, 2023 Author Share Posted April 2, 2023 Pics aren't really suitable for this forum. 2 2 Quote Link to comment Share on other sites More sharing options...
