Focus Mk3 Cruise Control button stopped working - how to open and clean contacts?
IceQubed
 Share
The steering wheel cruise control button on my mk3 focus has stopped working - when this happened about a year ago the garage said they cleaned the contacts and it started working again. Recently it's failed again so it's time to open it up and clean the contacts or just bite the bullet and replace the button assembly.
Does anybody have information on how to open this up to clean the button contacts?
Link to comment
  • 6 months later...
I never got a response but I'm still looking for a solution! Could anyone advise how I should proceed?
Link to comment
Cleaning contacts rarely works for long in my experience.  Just replace the switch imo.
Link to comment
Is there any information on how to remove / get in to the button / switch assembly?
Link to comment
You just need to remove the airbag and then the switch is screwed to the inside of the wheel casing.
The airbag is held in by a big spring clip that needs to be levered out each side.
Can probably find a better video if you search YouTube but this is the first one I found...
Link to comment
Thanks! I managed to find a (likely aftermarket copy) listing for a switch:
https://www.aliexpress.com/item/32841881924.html
I think I may have managed to get the part number for this part:
DT1T-9E740-AA
aka
DT1T9E740AA
Though this part number seems to also find a bunch of similar but incorrect other cruise control button assemblies.
I have no idea if £61 is a good price or not but I haven't found it elsewhere yet... I hoped there might be some way to get an OEM part.
Link to comment
May be worth checking eBay? Although you might not get a brand new switch you might have some luck. I retrofitted cruise control to two focuses and got the steering wheels with switches for £25 each.
Link to comment
I think this is the correct Ford service part number (the type the dealers use) - 1782873.  If you contact your closest main dealer and ask them to quote a price for it, that should give you a good base price to work from.  Oddly, I can't find any new on eBay.
I think all of the superceeding part numbers will still work (the dash type number you have) as long as it's from a car with the same spec as yours - presumably basic cruise & limiter.  Adaptive cruise switches are different, as are non-limiter switches.  From a quick eBay search I've come across these used, but would suggest double checking before purchasing any.
Ford C-MAX II 2014 Cruise control switch AM5T9E740AA BOS15119 | eBay
FORD KUGA MK2 CRUISE CONTROL BUTTONS 2013-2016 RO15 | eBay
FORD KUGA MK2 CRUISE CONTROL SWITCHES 2013-2016 LJ15 | eBay
FORD KUGA CRUISE CONTROL BUTTONS MK2 2013-2016 KR65 | eBay
FORD KUGA MK2 CRUISE CONTROL BUTTONS 2013-2016 LL15 | eBay
FORD KUGA MK2 2013-2016 CRUISE CONTROL BUTTONS YX64 | eBay
Or as above, it's actually cheaper to buy a whole used wheel to take the switch from.
Ford Focus Steering Wheel Leather Cruise 4 Spoke Volume Control Call 2011-2014 | eBay
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
  • Insurance
  • Support
