Ian Lockley Posted September 14, 2021 Share Posted September 14, 2021 Is there a way to open the boot while battery is disconnected. Under the ford badge there is a finger bar that releases the lock when battery is connected . I thought it was a manual opener. It released to first catch but boot won't open . 2011 1.6 dtci Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted September 15, 2021 Share Posted September 15, 2021 Is it still locked on central locking? Quote Link to comment Share on other sites More sharing options...
BigLen Posted September 15, 2021 Share Posted September 15, 2021 10 hours ago, Ian Lockley said: Is there a way to open the boot while battery is disconnected. Under the ford badge there is a finger bar that releases the lock when battery is connected . I thought it was a manual opener. It released to first catch but boot won't open . 2011 1.6 dtci only way to open it without the battery is to get inside the boot via the back seat, look on the lower boot panel you will see two small square flaps; pop those open with a flat head screw-driver then using a TX40 torx but; undo the two bolts which hold in the bottom section of the boot latch, the boot will then open when both of these bolts are removed. 2 1 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted September 15, 2021 Share Posted September 15, 2021 7 minutes ago, BigLen said: only way to open it without the battery is to get inside the boot via the back seat, look on the lower boot panel you will see two snall square flaps; pop those open with a flat head screw-driver then using a TX40 torx but; undo the two bolts which hold in the bottom section of the boot latch, the boot will then open when both of these bolts are removed. What a great design feature! Ford definitely on form with that one... 🤣 2 Quote Link to comment Share on other sites More sharing options...
BigLen Posted September 15, 2021 Share Posted September 15, 2021 4 minutes ago, StephenFord said: What a great design feature! Ford definitely on form with that one... 🤣 should have swapped the boot latch with the bonnet one, Quote Link to comment Share on other sites More sharing options...
Eric Bloodaxe Posted September 15, 2021 Share Posted September 15, 2021 4 minutes ago, StephenFord said: What a great design feature! Ford definitely on form with that one... 🤣 Not just Ford. I had to do as Lenny describes when the boot lock failed on my Peugeot 309 GTI 30 odd years ago. We 'd just arrived at our holiday cottage and I had to crawl in there to get our stuff! 1 Quote Link to comment Share on other sites More sharing options...
BigLen Posted September 15, 2021 Share Posted September 15, 2021 9 minutes ago, StephenFord said: What a great design feature! Ford definitely on form with that one... 🤣 Quote Link to comment Share on other sites More sharing options...
BigLen Posted September 15, 2021 Share Posted September 15, 2021 5 minutes ago, Eric Bloodaxe said: Not just Ford. I had to do as Lenny describes when the boot lock failed on my Peugeot 309 GTI 30 odd years ago. We 'd just arrived at our holiday cottage and I had to crawl in there to get our stuff! my wife closed the boot on my rain jacket once; in the mk2.5 focus few years ago, the arm of the jacket got caught up in the latch and jammed tight, had to get in to the boot and remove the bottom latch; followed by pressing the boot handle and swinging out of the jacket to pull it free. that was the best Sunday of my life to date. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted September 15, 2021 Share Posted September 15, 2021 Top tip...don't keep your jump leads in the boot! 1 Quote Link to comment Share on other sites More sharing options...
BigLen Posted September 15, 2021 Share Posted September 15, 2021 1 minute ago, TomsFocus said: Top tip...don't keep your jump leads in the boot! keep one of these in the deep glovebox Mighty Jump Emergency 12V Car Battery Jump Starter - Portable Small Carry On New | eBay Quote Link to comment Share on other sites More sharing options...
Ian Lockley Posted September 15, 2021 Author Share Posted September 15, 2021 All sorted now thanks .just waited till I re connected battery. 1 1 Quote Link to comment Share on other sites More sharing options...
