beng2021 Posted October 14, 2021 Share Posted October 14, 2021 Judt installed a new battery in my 07 focus and need a step by step of resetting computer if this is required please 1 Quote Link to comment Share on other sites More sharing options...
Janner7859 Posted October 14, 2021 Share Posted October 14, 2021 I have removed, re-installed, and replaced the battery in my 57 focus a few times, and have never found it necessary to reset anything other than the radio. Unless you are getting any unusual problems, I wouldn't worry about it. If it is needed, I'm sure someone with more knowledge than me will put you right. 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted October 14, 2021 Share Posted October 14, 2021 just take it for a good run and it self learns the setting Quote Link to comment Share on other sites More sharing options...
unofix Posted October 14, 2021 Share Posted October 14, 2021 27 minutes ago, beng2021 said: 07 focus and need a step by step of resetting computer Hi, the 2007 doesn't have a BMS, so nothing to reset or clear. @StephenFord can you confirm there is no BMS or a 2007 ? Quote Link to comment Share on other sites More sharing options...
StephenFord Posted October 14, 2021 Share Posted October 14, 2021 3 minutes ago, unofix said: Hi, the 2007 doesn't have a BMS, so nothing to reset or clear. @StephenFord can you confirm there is no BMS or a 2007 ? I can confirm the 2005, and 2006 doesn't, must confess, I'm unsure about the 2007 - sorry... 1 Quote Link to comment Share on other sites More sharing options...
beng2021 Posted October 14, 2021 Author Share Posted October 14, 2021 cheers guys also i have got various codes up myself on the computer by using the reset button how accurate are these please Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted October 14, 2021 Share Posted October 14, 2021 21 minutes ago, beng2021 said: cheers guys also i have got various codes up myself on the computer by using the reset button how accurate are these please On what computer? Unless you've plugged in and read the codes using a reader then it's a waste of time. Quote Link to comment Share on other sites More sharing options...
unofix Posted October 14, 2021 Share Posted October 14, 2021 3 hours ago, beng2021 said: i have got various codes up myself on the computer If you are talking about the crazy little codes that you can get in the Instrument Cluster they are of little to no use to anyone. You need to read the real DTC's using a laptop and Forscan software. Quote Link to comment Share on other sites More sharing options...
