2014 Ranger 2.2 Dpf fault
Hi All,
So I recently had my ranger go into limp mode and when I read the codes via my OBD ELM 327 I get the attached codes.
I removed my DPF and brought it to a local Dpf cleaning centre and it came back as good as new.
I also replaced the exhaust sensor in the Dpf centre.
I removed the vaporiser and found it to be blocked, I cleared this and refitted it.
When I clear the codes with the OBD, it immediately goes back to limp mode and the same codes appear.
With accelerator fully pressed I'm not getting over 2500 rpm.
I can't force a regen as I don't have the elm lead for my laptop, I have it being delivered and I'll download forscan then.
Would anyone have any idea as to what the problem could still be ?
Does it need a regen before the codes completely clear?
I'm worried about putting it into a regen if there is some blockage still present which could cause a fire risk.
Thanks in advance.
Dave
