Garci3070 Posted December 20, 2021 Share Posted December 20, 2021 Hi guys. First, I would like to say It's a pleasure to be part of this forum and get the opportunity to share my knowledge with all of you. I'm trying to replace the ancient panel cluster without count rev for another one with count rev. Originally Escort 1.4 cl doesn't equipped count rev. I have the two connectors (blue and White) for the new panel with count rev. I'm following a guide that I found in www.escort-mk4.de (technics parte in the web site) Once I unplug all wires I follow the instructions but It doesn't work. I'm not sure that this guide was correct. In some cases I dont understand what It want to say. Are there anyone Who knows how to do It correctly? Thanks in advanced. You can find attached the guide. Quote Link to comment Share on other sites More sharing options...
Garci3070 Posted December 21, 2021 Author Share Posted December 21, 2021 No one??? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted December 21, 2021 Share Posted December 21, 2021 1 hour ago, Garci3070 said: No one??? Hi Jorge, I'm afraid there are very few Escort owners on here, generally we're dealing with cars under 20 years old so you may have to wait a while to get a suitable answer to your question. I think that guide must have been translated to English from German? It doesn't make much sense in English! Quote Link to comment Share on other sites More sharing options...
unofix Posted December 21, 2021 Share Posted December 21, 2021 Hello Jorge. A very, very, long time ago I did the same thing you are doing to a 1983 Orion. My Rev counter didn't work and I followed all the diagrams exactly. It turned out that there was a rev counter pulse transformer not shown on the Ford wiring diagram. I only realised the problem when I compared my car with another Orion that had a factory fitted rev counter. It is so long ago now that I don't have the part number anymore, but I can tell you that it is a very small black unit about 30mm x 20mm and is fitted next to the coil. The lead for the low voltage side just plugs in to the unit. After I fitted it the rev counter worked without any problems. I still have the wiring diagram, but sadly no information on the part you probably need to fit 1 Quote Link to comment Share on other sites More sharing options...
Dan62 Posted December 21, 2021 Share Posted December 21, 2021 The British translation on the website is bad, go to the German view and do a google translate yourself from there, it makes more sense. Unofix is spot on re the filter, see attached pics, and luckily the original part is still available. Its just an inline noise suppression filter. How far have you got with the conversion? do all the lamps and gauges work except for the Tacho? 1 Quote Link to comment Share on other sites More sharing options...
Garci3070 Posted December 21, 2021 Author Share Posted December 21, 2021 Thank you. At first moment I did work the count rev but other things like lighting not. After several changes work everything except tacho and fuel gauge. I gave it up and swap to the original panel without tacho and none indicador light(brake ,battery,oil) and temperature and fuel are working. What a Mess. Any idea what I did wrong. Thanks Quote Link to comment Share on other sites More sharing options...
Dan62 Posted December 21, 2021 Share Posted December 21, 2021 That's not good, I can't help you on that. Quote Link to comment Share on other sites More sharing options...
Garci3070 Posted December 21, 2021 Author Share Posted December 21, 2021 Thanks. I"ll try to find out what is the problem. Quote Link to comment Share on other sites More sharing options...
