SiW0020 Posted January 14, 2022 Share Posted January 14, 2022 Hi all, I have a UK SMAX, TitaniumX, 2.0 Duratec, 2012 Model. It has the auto-sensing load adjustment for the front headlights, when the boot is loaded or towing (rather than having a manual switch on the dashboard). I now have a spare tyre in the boot (I had an issue last year where I got a puncture and the inflation kit was worse than useless, and having to try and get it sorted on a campsite!!) and the front lights don't seem to be adjusting down enough to compensate. Is there a way to adjust please? Regards, SW Quote Link to comment Share on other sites More sharing options...
Frembrit Posted January 14, 2022 Share Posted January 14, 2022 If it's auto height levelling Bi-Xenon headlights then no, there isn't a manual way to adjust. This is on the assumption that they were correctly adjusted beforehand on the mounting adjusters (would have failed MOT if it wasn't...but I've never seen an MOT tester check the aim of my Xenon's). How does the beam spread/aim look? are people flashing you (more than normal)? I don't think the spare wheel would make the rear go down enough really, it's only 15-20 kg. Quote Link to comment Share on other sites More sharing options...
SiW0020 Posted January 14, 2022 Author Share Posted January 14, 2022 Yes, with spare in boot, get flashed a lot 😞 Since spare was added..... I'll have to check it. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted January 14, 2022 Share Posted January 14, 2022 Perhaps one of your suspension level sensors has broken so it's not reading the correct level? 1 Quote Link to comment Share on other sites More sharing options...
SiW0020 Posted January 14, 2022 Author Share Posted January 14, 2022 Just passed it's MOT, so should have been sorted in that? (if a sensor was an issue) Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted January 14, 2022 Share Posted January 14, 2022 5 hours ago, SiW0020 said: Just passed it's MOT, so should have been sorted in that? (if a sensor was an issue) Was the spare wheel in the boot at time of the test? As above, some testers aren't very thorough and don't check the beam height properly so I'd still double check the sensors personally. You can't adjust the height of both beams manually so if it's not a sensor fault and it's not a single headlight fault (one side sitting high) then you'll need a garage to use their beam tester and manually adjust each light unit individually to the correct level. Quote Link to comment Share on other sites More sharing options...
