RTL Posted March 9, 2022 Share Posted March 9, 2022 Hi all, Not sure if this is the right place to post this. I bought an upgraded instrument cluster for my Focus mk3 (pre facelift) I knew I’d need to get the odometer adjusted to my actual mileage once fitted and I was told Ford could do it for me. But my local Ford garage insisted that it can’t be done although I know some of you guys have done it. So I’m wondering if there’s anyone local to Rainham, Kent that has the equipment to do it and could help me out? I’ll pay obviously. Quote Link to comment Share on other sites More sharing options...
unofix Posted March 9, 2022 Share Posted March 9, 2022 Hello Richard, Mileage on any Ford instrument cluster can only be increased (moved up) it can not be reduced (even by the Ford garage). When ever an instrument cluster is replaced by a used/second hand unit it is very important that the replacement has less mileage than the one it replaces. Using a licensed version of the software FORScan you can adjust the mileage of the replacement up. 2 Quote Link to comment Share on other sites More sharing options...
RTL Posted March 10, 2022 Author Share Posted March 10, 2022 Hi , thanks for reply. I made sure I got a lower mileage one. So just need it adjusted up. The Ford garage just refused outright and said it can’t be adjusted at all. What do I need to use Forscan? I didn’t really want to have to spend loads on equipment just to do the one thing. But if I have to then suppose I can sell it afterwards. Quote Link to comment Share on other sites More sharing options...
mjt Posted March 10, 2022 Share Posted March 10, 2022 If you have a Windows laptop the equipment and software you need will cost less than having a Ford garage do it and you will be able to use it to diagnose faults in the future so it's a win-win. You just need a modified ELM327 cable and Forscan which is a free download. You then need to buy a 1-year Forscan licence to do the adjustment. The licence isn't needed for reading fault codes so when it expires you can still use it for that. Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted March 10, 2022 Share Posted March 10, 2022 You don't need a paid license just a free extended to move mileage up. 1 Quote Link to comment Share on other sites More sharing options...
mjt Posted March 10, 2022 Share Posted March 10, 2022 I stand corrected. 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 10, 2022 Share Posted March 10, 2022 FORScan: https://forscan.org/download.html New style 'vLinker FS' lead for use with the latest version of FORScan: https://www.bmdiag.co.uk/forscan-diagnostic-cable-for-ford-vgate-vlinker-fs Quote Link to comment Share on other sites More sharing options...
RMurphy195 Posted March 10, 2022 Share Posted March 10, 2022 OTOH why bother? Just keep records so that when you sell the car on, you can provide an audit trail of the replacement. Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted March 11, 2022 Share Posted March 11, 2022 15 hours ago, RMurphy195 said: OTOH why bother? Just keep records so that when you sell the car on, you can provide an audit trail of the replacement. It takes seconds to do in Forscan, why leave it? 2 Quote Link to comment Share on other sites More sharing options...
RTL Posted March 11, 2022 Author Share Posted March 11, 2022 Thanks for the info everyone. I’ll have to get the cable and software and give it a go. Quote Link to comment Share on other sites More sharing options...
Nathan Buffery Posted March 11, 2022 Share Posted March 11, 2022 On 3/9/2022 at 7:12 PM, unofix said: Mileage on any Ford instrument cluster can only be increased (moved up) it can not be reduced (even by the Ford garage). Ok. Maybe a stupid question...but.... Could a used cluster that has more mileage than your car, be increase up to 99999 with Forscan. Driven 2 miles, hopefully reading 00001. And then increase again to match the actual mileage? Quote Link to comment Share on other sites More sharing options...
unofix Posted March 11, 2022 Share Posted March 11, 2022 1 hour ago, Nathan Buffery said: Ok. Maybe a stupid question...but.... An interesting idea but probably no. The odometer actual goes to 999,999 and since Ford aren't expecting cars to do a million miles it will probably just explode ! A word of caution to anyone who might be thinking of trying this. The true mileage of the vehicle is also recorded in many of the modules in the car like the ECU, BCM, PDM, DDM. If you increase the mileage in the instrument cluster to 999,999 then it is a fair bet that all these modules will do the same. Then the big question is can they be rolled past zero ? 1 Quote Link to comment Share on other sites More sharing options...
Nathan Buffery Posted March 12, 2022 Share Posted March 12, 2022 I'm guessing there will be a bigger motivation to wind back the mileage, when we start getting charged for the miles we drive. When I had a diesel car in New Zealand, you get an extra charge for the amount of Kilometres you drive. The locals said they have a hidden switch which turns off the speedo. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted March 12, 2022 Share Posted March 12, 2022 9 hours ago, Nathan Buffery said: Ok. Maybe a stupid question...but.... Could a used cluster that has more mileage than your car, be increase up to 99999 with Forscan. Driven 2 miles, hopefully reading 00001. And then increase again to match the actual mileage? That will not work. From experience I can tell that doing this will lock the mileage at 99999 Miles 8 hours ago, unofix said: A word of caution to anyone who might be thinking of trying this. The true mileage of the vehicle is also recorded in many of the modules in the car like the ECU, BCM, PDM, DDM. If you increase the mileage in the instrument cluster to 999,999 then it is a fair bet that all these modules will do the same. Then the big question is can they be rolled past zero ? On a Focus MK3/MK3.5 the mileage is only stored in the instrument cluster. All other modules that show the mileage during diagnostics just synchronise with the instrument cluster. After I installed a 0 Miles instrument cluster into my Focus MK3 all other modules also showed the 0 Mileage. Some Focus MK3/MK3.5 modules do not show the correct mileage anyway because the mileage of these modules is reset every time a software update is performed. With the correct tools the instrument cluster mileage can easily be changed downwards. I even managed to lower the mileage using a cheap ELM327 interface, a terminal software (for example PuTTY) and the correct AT commands (this however requires a lot of knowledge and experience). Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted March 12, 2022 Share Posted March 12, 2022 10 hours ago, Nathan Buffery said: Ok. Maybe a stupid question...but.... Could a used cluster that has more mileage than your car, be increase up to 99999 with Forscan. Driven 2 miles, hopefully reading 00001. And then increase again to match the actual mileage? No, because they go 999,999 now (million miles) Quote Link to comment Share on other sites More sharing options...
jlawes20389 Posted March 12, 2022 Share Posted March 12, 2022 If you haven't got it sorted, feel free to give me a shout. I'm the other side of the bridge but can do it if you get stuck. Quote Link to comment Share on other sites More sharing options...
unofix Posted March 12, 2022 Share Posted March 12, 2022 4 hours ago, JW1982 said: cluster mileage can easily be changed downwards 4 hours ago, JW1982 said: a terminal software (for example PuTTY) and the correct AT commands (this however requires a lot of knowledge and experience). Kind of contradicts the statement "easily be changed downwards" 🤣 Shall we say that for 99% of users moving the mileage backwards is not something to try and undertake. I agree with the fact that the modules reflect the mileage of the IC, my point was if you move that to 999,999 would the modules be able to roll over past zero. I don't know the answer to that. Quote Link to comment Share on other sites More sharing options...
unofix Posted March 12, 2022 Share Posted March 12, 2022 Can you please confirm on a Focus MK3/MK3.5 is the mileage 4 hours ago, JW1982 said: only stored in the instrument cluster. Or do the modules actually record/store the mileage as you say they: 4 hours ago, JW1982 said: do not show the correct mileage anyway because the mileage of these modules is reset every time a software update is performed. Or do the the modules 4 hours ago, JW1982 said: that show the mileage during diagnostics just synchronise with the instrument cluster Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted March 13, 2022 Share Posted March 13, 2022 19 hours ago, unofix said: Can you please confirm on a Focus MK3/MK3.5 is the mileage Or do the modules actually record/store the mileage as you say they: Or do the the modules Mileage is stored the the IPC and ABS module IIRC 1 Quote Link to comment Share on other sites More sharing options...
RTL Posted March 13, 2022 Author Share Posted March 13, 2022 23 hours ago, jlawes20389 said: If you haven't got it sorted, feel free to give me a shout. I'm the other side of the bridge but can do it if you get stuck. Ok awesome, thank you. Quote Link to comment Share on other sites More sharing options...
stuballs1973 Posted January 20 Share Posted January 20 I know this is an old thread but you guys don't half chat some bubbles . The mileage is easily changed in either direction , it isn't stored in all those locations on fords , in the diesels its stored in the cluster and the PCM in petrols only the cluster , any half decent diaganostics will write the mileage up but it WILL NOT go past 999999 Quote Link to comment Share on other sites More sharing options...
