xaspar30 Posted March 20, 2022 Share Posted March 20, 2022 Just did this today with the help of some picture i found on here, so I figured there may be some interest in this so ill make a post about it. If you're interested in how to do this mod just reply or something and I'll post a little guide. All of the stuff needed fits inside the radio itself so you wont see anything from the outside and you'll be able to play music via bluetooth. switching to bluethooth is done by pressing the aux button and the bluethooth module won't turn on unless you have the key inserted and turned 1 click. (my car is an ford focus 2006? but it will probably work with other cars aswell, as long as the radio is the same. 1 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted March 20, 2022 Share Posted March 20, 2022 1 hour ago, xaspar30 said: Just did this today with the help of some picture i found on here, so I figured there may be some interest in this so ill make a post about it. If you're interested in how to do this mod just reply or something and I'll post a little guide. Well done buddy, there are frequent queries on here on how to add blutooth to a 6000CD, often just using a separate blutooth module which then sometimes adds a whole new tier of issues. Good to see a mod like this but obvious soldering iron skills are needed! Welcome to the forum... Quote Link to comment Share on other sites More sharing options...
xaspar30 Posted March 20, 2022 Author Share Posted March 20, 2022 37 minutes ago, StephenFord said: Well done buddy, there are frequent queries on here on how to add blutooth to a 6000CD, often just using a separate blutooth module which then sometimes adds a whole new tier of issues. Good to see a mod like this but obvious soldering iron skills are needed! Welcome to the forum... yup some soldering skills are required but its pretty simple stuff and not too small so even relative beginners should be fine. I'll test if this gives me any problems and if it doesn't I'll post some pictures of where to solder and what to buy. 1 Quote Link to comment Share on other sites More sharing options...
