Is This Unique To Ecosports?
Turvey
聽Share
Been noticing these ugly marks underneath the door mirrors on both sides!聽
They seem easy to clean off but they annoy the hell out of me 馃檮
Not noticed it on the 2 Fiestas in the household so is it just an EcoSport thing? Any easy way to fix it? Apart from washing it more often! 馃榾
Its where the door mirror drains, seen this on other cars not just Ford.
  • Like 2
Never had that problem with my Ecosport, do you fold them in when you park up only some people I know prefer to leave them out and I wonder if the weather gets inside whilst parked.
Ah, I see the problem here...your indicator fluid is leaking. :wink:
There must be some grime stuck somewhere if that's constantly coming out of the mirror base.聽 I think it's just needs a 'good' clean once, rather than more cleaning.聽 You can see the small drain hole in your picture.聽 Getting something in there would be a good start...perhaps compressed air or plain water to avoid any risk to other components.聽 If the mirror glass is easy enough to remove, I'd also want to clean behind/underneath that.
  • Haha 1
I've just paid extra to get it topped up as well! 馃檮馃榾
  • Haha 1
Just had a wee (careful) poke with a screwdriver into the drain hole and a fair amount of chalky deposit fell out so I'm thinking of getting the outer cover off and give it a proper clean 馃憤
Set to fold when locked but don't lock it very often! Parked on a drive in a low crime rate area 馃槈
  • Like 2
Chalky deposits is most likely aluminium corroding聽
  • Sad 1
Correct! 馃槻
  • Sad 2
23 minutes ago, Turvey said:
Correct! 馃槻
Oh yes!!!! . Oh yes!!!!!. Yay. I'm right for once. That was a lucky guess.聽
Sorry, I mean that's not looking good.聽
  • Haha 3
No, it's not! Salty atmosphere obviously doesn't do aluminium many favours.聽
Thinking a wash with white vinegar and a brush would clean the worst of it away? Would a quick spray of lacquer help to slow down it happening again?聽
No idea, I'm not an aluminium expert聽
  • Haha 1
馃檮 馃榾
Driver's side was worse! 馃槻
  • Sad 1
It's dendritic growth, a common problem with many soft alloys. The mirror bracket is made from an aluminum alloy (commonly referred to as white metal). This is the reason it is very difficult to paint aluminum, and the reason for the need to always use an etch primmer, otherwise the dendrictic growth continues to form under the paint and eventually it falls off.
Give the bracket a good brush down to remove the loose white powder and then a good spray with WD40 (or similar), or even a light spray with 3 in 1 oil. There is no point it trying to paint it as you will be unable to get it clean enough, and as I've said you would need to use an etch primer first.
  • Like 4
  • Thanks 1
Nor me.聽 Now, if it was Titanium... :biggrin:
  • Haha 1
To be fair when I first read the first post I thought Turvey was referring to the whole car as being ugly both sides. The front and backs no better. 馃ぃ馃ぃ馃ぃ馃ぃ
  • Haha 1
Harsh! 馃榾
Harsh! 馃榾
Yep馃ぃ馃ぃ
To be fair I've seen worse looking cars on the road! 馃槻馃榾
Only reason we buy higher cars is because Mrs Turvey has disintegrating discs and finds it very difficult to get in and out of anything lower.聽聽
聽 Pasted as rich text. 聽聽Paste as plain text instead
聽 Only 75 emoji are allowed.
聽 Your link has been automatically embedded. 聽聽Display as a link instead
聽 Your previous content has been restored. 聽聽Clear editor
聽 You cannot paste images directly. Upload or insert images from URL.
聽Share
