Fix-Or-Repair-Daily Posted May 25, 2022 Share Posted May 25, 2022 Hi all I'm going to be servicing my 2012 focus 1.6 ecoboost this weekend, what should the spark plug gap be? Thanks 1 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 25, 2022 Share Posted May 25, 2022 28 minutes ago, Fix-Or-Repair-Daily said: Hi all I'm going to be servicing my 2012 focus 1.6 ecoboost this weekend, what should the spark plug gap be? Thanks i am also wanting to know this too. i normally get boshe ones and i dont do anything to the gap but after reading your post, i had to google it. apparently it does the engine good and idles very good if gapped properly. just found this: its quite old but seems quite useful info. Quote Link to comment Share on other sites More sharing options...
south_bound Posted May 25, 2022 Share Posted May 25, 2022 Does it become obvious if the gap becomes out of spec, like the engine is ding lumpy or something? It's just that my wife's VW is coming up to 15 years old and never checked the plugs in all that time. 1 Quote Link to comment Share on other sites More sharing options...
Jimpster Posted May 25, 2022 Share Posted May 25, 2022 if you buy the specific plugs they usually come pre gapped 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 25, 2022 Share Posted May 25, 2022 31 minutes ago, south_bound said: Does it become obvious if the gap becomes out of spec, like the engine is ding lumpy or something? It's just that my wife's VW is coming up to 15 years old and never checked the plugs in all that time. I really wouldn't want to have to loosen 15 year old plugs! 2 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 25, 2022 Share Posted May 25, 2022 2 hours ago, Jimpster said: if you buy the specific plugs they usually come pre gapped which spark plugs do you get for your focus? Quote Link to comment Share on other sites More sharing options...
south_bound Posted May 26, 2022 Share Posted May 26, 2022 11 hours ago, TomsFocus said: I really wouldn't want to have to loosen 15 year old plugs! Thanks Tom, sounds like a good reason to leave them as they are then. I suppose you will say the same thing about the original injectors fitted to my 15 year old Mk 2 Focus diesel? 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 26, 2022 Share Posted May 26, 2022 1 hour ago, south_bound said: I suppose you will say the same thing about the original injectors fitted to my 15 year old Mk 2 Focus diesel? DV6 injectors & injector nuts tend to loosen themselves over time, they're probably not too bad. I wouldn't want to risk the glowplugs if they haven't been changed in 15 years though. Quote Link to comment Share on other sites More sharing options...
Fix-Or-Repair-Daily Posted May 26, 2022 Author Share Posted May 26, 2022 I bought Bosch plugs from euro car parts. Yes the spark plug gap does affect running and how complete the burn is inside the engine. I found a video on YouTube saying it should be 0.7mm but someone in the comments said it should be 0.6mm. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted May 27, 2022 Share Posted May 27, 2022 Ford prescribes to adjust the spark plug gap of the 1.6 ECOboost to 0.8 mm. The following spark plug gaps are prescribed by Ford for the Focus MK3/MK3.5: 1.6 Duratec TI-VCT = 1,20 mm (0,7-0,8 mm for LPG versions). 1.0 ECOboost = 0,7 mm. 1.5 ECOboost = 0,8 mm. 1.6 ECOboost = 0,8 mm. 2.0 Duratec HE TI-VCT = 0,9 mm. 2.0 ECOboost ST = 0,8 mm. 2.3 ECOboost RS = 0,75 mm 2 2 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 27, 2022 Share Posted May 27, 2022 will the gap matter on the 1.6 ghia? been recommended to buy any good brands. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted May 28, 2022 Share Posted May 28, 2022 Yes it will matter. For your 1.6 Duratec engine the spark plug gap needs to be set to 1.2 mm. 1 Quote Link to comment Share on other sites More sharing options...
Jimpster Posted May 28, 2022 Share Posted May 28, 2022 2 hours ago, JW1982 said: Yes it will matter. For your 1.6 Duratec engine the spark plug gap needs to be set to 1.2 mm. whats that in thou as i believe thats what feeler guages work in 🤣 Quote Link to comment Share on other sites More sharing options...
agraham Posted May 28, 2022 Share Posted May 28, 2022 1 inch = 25.4 mm exactly 1mm = = 0.0393 inches = 39.3 thou 1.2mm x 39.3 thou = 47 thou 4 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 28, 2022 Share Posted May 28, 2022 3 minutes ago, Jimpster said: whats that in thou as i believe thats what feeler guages work in 🤣 Depends if you bought your feeler gauge this century I guess... 2 Quote Link to comment Share on other sites More sharing options...
iantt Posted May 28, 2022 Share Posted May 28, 2022 8 minutes ago, TomsFocus said: Depends if you bought your feeler gauge this century I guess... Mine are in imperial . Plugs used to be 25thou and points 15thou. . That's showing my age!! 3 Quote Link to comment Share on other sites More sharing options...
Tizer Posted May 28, 2022 Share Posted May 28, 2022 And I can remember when if you couldn't find your feeler gauges to set your points then the thickness of your cigarette packet cardboard was about the same. 3 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 28, 2022 Share Posted May 28, 2022 many thanks guys never done a gapping before, i will buy some boshe and the feeler gauge. many thanks guys Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 28, 2022 Share Posted May 28, 2022 i have had a look on eBay but all the feeler i have seen only goes to 1mm. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 28, 2022 Share Posted May 28, 2022 40 minutes ago, froggy8 said: i have had a look on ebay but all the feeler i have seen only goes to 1mm. You can use two blades together. So 1mm and 0.2mm. (Or any other combination that makes 1.2 if you fancy a challenge. ) 2 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 28, 2022 Share Posted May 28, 2022 5 minutes ago, TomsFocus said: You can use two blades together. So 1mm and 0.2mm. (Or any other combination that makes 1.2 if you fancy a challenge. ) thank you and sorry for silly questions. i will just buy any in that case. 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 28, 2022 Share Posted May 28, 2022 30 minutes ago, froggy8 said: thank you and sorry for silly questions. i will just buy any in that case. Not silly questions, things are only easy when you know! 1 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 28, 2022 Share Posted May 28, 2022 3 minutes ago, TomsFocus said: Not silly questions, things are only easy when you know! thank you i have always bought any sparkplugs and just fit them in. just means that ford is bit more fussy than other brands. Quote Link to comment Share on other sites More sharing options...
Jimpster Posted May 28, 2022 Share Posted May 28, 2022 there are NO silly qustions, just ones to which you dont know the answer yet, plugs usually come pregapped for the make model but can move due to knocking and banging always best to check before just throwing them in. 1 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 28, 2022 Share Posted May 28, 2022 which sparkplug adjuster do you all buy? this one: https://www.ebay.co.uk/itm/265120981995?hash=item3dba7123eb:g:C18AAOSwGxNgc8vn or this one: https://www.ebay.co.uk/itm/184958159987?epid=1605402839&hash=item2b105d8c73:g:PxQAAOSwEhJg-R1T Quote Link to comment Share on other sites More sharing options...
