Bigtone46 Posted June 13, 2022 Share Posted June 13, 2022 2007 Focus cc3 cabriolet. The roof retracts perfectly OK and front windows work OK but when roof is up both front windows go down and stay down until roof is down when they work OK again! Can't find a Ford dealer willing to look at it, Ford UK say try a ford body shop but they won't look at it either. I can buy an ECU for £99.95 from roof motors UK but would like a wiring diagram first. Any one on the forum know of a link to a wiring diagram please? Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted June 13, 2022 Share Posted June 13, 2022 The system has sensors to tell it it's in the fully up position, one of these is obviously not working 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted June 13, 2022 Share Posted June 13, 2022 There are about 12 sensors/switches for the operation of the roof. It is not an easy job to find the one with a problem. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted June 13, 2022 Share Posted June 13, 2022 Forscan may be able to tell you which sensor is at fault. Though it could also be a wiring fault from that sensor of course. I'm a bit surprised the main dealer didn't even offer to plug it in? Easy £75 for them! 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted June 13, 2022 Share Posted June 13, 2022 Just now, TomsFocus said: Forscan may be able to tell you which sensor is at fault. Though it could also be a wiring fault from that sensor of course. I think you are correct Tom, using FORScan will show which sensor/switch is not operating, but I seem to recall the problem that nearly everyone has is actually finding the physical location on the car 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted June 13, 2022 Share Posted June 13, 2022 1 minute ago, unofix said: I think you are correct Tom, using FORScan will show which sensor/switch is not operating, but I seem to recall the problem that nearly everyone has is actually finding the physical location on the car Fair point. 7Zap gives a rough idea - Folding Roof Sensors FORD Focus Cabriolet 2006-2010 (CA5) (7zap.com) 2 Quote Link to comment Share on other sites More sharing options...
Bigtone46 Posted June 14, 2022 Author Share Posted June 14, 2022 Thanks gents, that's another step forward but I think I still need a wiring diagram to check what the sensors should be putting out ie short when closed/ nil when open? Quote Link to comment Share on other sites More sharing options...
unofix Posted June 14, 2022 Share Posted June 14, 2022 On 6/14/2022 at 9:33 AM, Bigtone46 said: I think I still need a wiring diagram to check what the sensors should be putting out ie short when closed/ nil when open? The best you are likely to get easily is a Haynes workshop manual with some wiring diagrams. FORScan will confirm if switches are open circuit or short circuit and should highlight any that are incorrectly operating. 1 Quote Link to comment Share on other sites More sharing options...
Bigtone46 Posted June 16, 2022 Author Share Posted June 16, 2022 Thanks, I'll try for a haynes manual first. Quote Link to comment Share on other sites More sharing options...
Bigtone46 Posted June 21, 2022 Author Share Posted June 21, 2022 Hi all, Haynes don't do a manual which covers the cabriolet and all my local Ford dealers ( all given to me by Ford UK) say they can't diagnose faults on the roof so still need a wiring diagram which seems to be as rare as rocking horse S**t. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted June 21, 2022 Share Posted June 21, 2022 Have you tried Forscan yet? The only chance you've got of finding diagram is either someone that works for Ford with full access to ETIS or someone that works at an indy garage with access to Autodata. I don't think it'll be readily available online. Quote Link to comment Share on other sites More sharing options...
Bigtone46 Posted June 22, 2022 Author Share Posted June 22, 2022 Hi Tom, I've tried all my local ford dealers within 30 miles and they all say they can't scan a CC3 cabriolet! Ford UK is no help either, all they give me is the dealers I have already tried. Still trying your suggestions for Autodata and Ford ETIS. I have a friend who had a Ford ranger which burnt out a wiring loom and Ford couldn't source the correct loom, no-one local was willing to rebuild the loom from scratch so he was forced to scrap it! Might end up doing the same for the Focus which would be a shame as it's low mileage and good condition! Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted June 22, 2022 Share Posted June 22, 2022 3 minutes ago, Bigtone46 said: Hi Tom, I've tried all my local ford dealers within 30 miles and they all say they can't scan a CC3 cabriolet! Ford UK is no help either, all they give me is the dealers I have already tried. Still trying your suggestions for Autodata and Ford ETIS. Forscan isn't the main dealer diagnostics. It's an app for individuals to use on a laptop or smart phone. Costs about £20 for the adapter but more than pays for itself the first time it's used! Sorry that wasn't explained earlier, it's mentioned so often on here I just assume everyone knows what it is by now! It's also not true that main dealers can't find cabriolet faults on their tool. Literally a month ago we had a member on here looking for a part after Ford had provided the fault code but then didn't know which part needed replacing or how to do it! The search is pretty ineffective on here but you may find that thread if you have a bit of spare time. @iantt Might be able to help with a wiring diagram... Quote Link to comment Share on other sites More sharing options...
Bigtone46 Posted June 23, 2022 Author Share Posted June 23, 2022 Hi Gents, thanks Tom for the link to Ian, he has sent me the roof wiring diagrams and I have just found the local Volks shop guy thinks he has the diagnostic software so between us we might finally solve the problem. (Found him through the friend of a friend). Got to take it on a dry day though as the windows won't close! Once again thanks Tom and especially Ian. Watch this space for results Tony 1 Quote Link to comment Share on other sites More sharing options...
Peter King Posted August 22, 2022 Share Posted August 22, 2022 Reading through your post, did you have any luck getting your windows sorted? Regarding finding a main dealer to deal with the CC, when we bought our CC brand new back in 2007 not all Ford main dealers were designated as CC dealers. They used to equip and train a specialist technician in a designated area dealership. Not sure if that still applies 15 years later but it might be a reason why people find it difficult to get support from non CC dealerships. 2 Quote Link to comment Share on other sites More sharing options...
Bigtone46 Posted September 1, 2022 Author Share Posted September 1, 2022 Hi all, thanks to every one who pitched in with suggestions. Found a roof repair company in Chester called Hoodtech run by a young guy called Charlie. All he does is soft tops and hard tops, manual and electric. Very busy, it took 4 weeks to get an appointment. Only 2 hours away from me so arrived at 10.00 and by 10.45 he had found the sensors that were the cause of the problem. Very clean workshop and a nice guy. He wanted the car for a week to suss out whether sensors, wiring or ECU. Turned out to be the ECU. New ECU and all back to normal complete with a warranty. Only problem was it cost £700 but had to be done or car was not worth anything. Daughter now happy and is keeping the car. As an aside, came back from Chester to north Worcestershire on 4 buses with my bus pass! Took 5 hours to do 80 miles but at least it was free! Peter, even the dealer she bought it off has no-one trained on CC! 2 Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted September 1, 2022 Share Posted September 1, 2022 Glad you've sorted it, finally. Quote Link to comment Share on other sites More sharing options...
Wojtas Posted May 2, 2023 Share Posted May 2, 2023 Hi can you send me wiring diagram? I’ve got roof problem with my focus cc. No idea how to check which one sensor should replace. I wonder witch one is NO or NC. Quote Link to comment Share on other sites More sharing options...
