woozyUK Posted July 11, 2022 Share Posted July 11, 2022 my friend has the above car and is finding it difficult to get a definitive answer of what oil type to use. Some say 5W30, some 5W40. He had 5W30 put in recently but with the temperatures were having ATM in the UK which is very hot at around 26-30+ degrees his car is running a bit lumpy, so maybe the oil is thinning too much in the heat so should he be using 5W40. IF 5W40, would this type be fine to use? Many thanks in advance. Quote Link to comment Share on other sites More sharing options...
unofix Posted July 11, 2022 Share Posted July 11, 2022 Use only 5W-30 as instructed by Ford. If you are unable to find an engine oil that meets the specification defined by WSS-M2C913-D or WSS-M2C948-B, it is acceptable to use a SAE 5W-30 engine oil that is defined by ACEA A5/B5. Ford KA+ owners handbook: https://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?variantid=4293&languageCode=en&countryCode=USA&Uid=G1858192&ProcUid=G1858193&userMarket=GBR&div=f&vFilteringEnabled=False Quote Link to comment Share on other sites More sharing options...
woozyUK Posted July 11, 2022 Author Share Posted July 11, 2022 thats the Ka+ isnt that different to the MK2 Ka? (based off the Fiat 500) Quote Link to comment Share on other sites More sharing options...
unofix Posted July 11, 2022 Share Posted July 11, 2022 Well if it is the older KA mk2 then as per Ford it uses 5W-40 only. https://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/ENUSA_CG3549_KAA_og_201407.pdf Quote Link to comment Share on other sites More sharing options...
woozyUK Posted July 11, 2022 Author Share Posted July 11, 2022 why reply with the Ka+ oil when I noted in the thread title it was the Ka Mk2? It could make someone use the wrong oil if it wasnt noticed Quote Link to comment Share on other sites More sharing options...
unofix Posted July 11, 2022 Share Posted July 11, 2022 Well the simple answer is RTFM and you wouldn't need anyone to try and help you !! Quote Link to comment Share on other sites More sharing options...
woozyUK Posted July 11, 2022 Author Share Posted July 11, 2022 His car didnt come with a fkin manual Quote Link to comment Share on other sites More sharing options...
woozyUK Posted July 11, 2022 Author Share Posted July 11, 2022 was hoping someone with a Ka themselves would reply! Quote Link to comment Share on other sites More sharing options...
