Glow plug fault
Hi guys, need some help with my 2012 wildtrak. So I bought it a few months back and it started playing up. Long story short it's just had a output speed sensor fitted and needs recoding. Now I have a fault on the obd saying glow plug 5 down. Can anyone tell me where it is ? I've been told that the recoding is likely to abort due to the fault so need to do it just incase. Thanks!
  • 3 months later...
What does recoding abort mean?
The output speed sensor? Is that the VSS gearbox speed sensor? then the recoding would be limited to the tyre circumference size being coded with ForScan?
Was the original problem related to wheel/tyre size changes, speedo, and limp mode when > a certain speed?
You are not going to get an answer from the OPW !!
They have not been back since making the post 12th July.
