Gunged thermostat!
Danbuoy1
 Share
Helping out a friend who has 1974 1300xl escort, had car rebuilt couple years back, recently said car overheated and asked my advice (as I have old Triumph and Mondy). Rebuilder has moved away and not local, not easy to get car to them.
Coolant flowed out of overflow as car warmed up.
Temp gauge didnt register, put new temp sensor in, gauge registered and coolant flowed out before it indicated "normal" but top hose/rad was cold. Took stat cover off and was staggered to find it was coated in a black gunge. It cleaned in water and lots of black bits and sediment in basin, tested and ok. Put back and this time all was much happier, maybe the gunge was shielding the stat? However (apart from recommending a  complete flush) any thoughts? Heard problems mixing antifreeze types altho guy says he hasn't added any, not sure myself...
Cheers
SD
Link to comment
A 1974 Escort would have used the old Ford BLUE coolant which I understand is now no longer available. You can use the Ford RED coolant which is the type used in all Ford cars now BUT the two types do not mix. If changing from the old blue coolant to the new red then the system needs a good flush first.
Link to comment
Many thanks for quick reply - confess I get confused by these colours - I use blue in my Triumph but red in our Ford's, the escort owner has a Cmax, just wondering if he used that antifreeze to top up escort and caused a problem. In my (50+ years) never seen a thermostat covered in what looks like black jelly!
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
