Gymfocused Posted August 26, 2022 Share Posted August 26, 2022 Can anyone please she'd some light on this message? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted August 26, 2022 Share Posted August 26, 2022 Well that's a crap code. Quote Link to comment Share on other sites More sharing options...
dezwez Posted August 26, 2022 Share Posted August 26, 2022 doesn't mean anything no code馃憤 Quote Link to comment Share on other sites More sharing options...
Gymfocused Posted August 26, 2022 Author Share Posted August 26, 2022 So why would it be throwing up the eml? There must be something doing it surely? The car runs fine, it's just bugging me. 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted August 26, 2022 Share Posted August 26, 2022 this is what's on google聽聽You don't need to panic if your car's check engine light turns on and says P0000. This code simply means that聽there is an issue with your scan tool. There's no need to take your car to the mechanic; you can safely drive it as usual. In most cases, the check engine light will turn off after a few days or weeks. 1 Quote Link to comment Share on other sites More sharing options...
Gymfocused Posted August 26, 2022 Author Share Posted August 26, 2022 Unfortunately, the light just stays on. I have to reset it in forscan. Is there something wrong with the pcm then? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted August 26, 2022 Share Posted August 26, 2022 Both of those codes are fairly generic and can be caused by plugging in the scantool.聽 Especially if tool quality is suspect. They can also point to a cluster fault, but I'd expect more codes if that was the case. Does the engine start and run ok? Quote Link to comment Share on other sites More sharing options...
Gymfocused Posted August 26, 2022 Author Share Posted August 26, 2022 13 minutes ago, TomsFocus said: Both of those codes are fairly generic and can be caused by plugging in the scantool.聽 Especially if tool quality is suspect. They can also point to a cluster fault, but I'd expect more codes if that was the case. Does the engine start and run ok? I'm using a cable from tunnelrat along with a licensed copy of forscan. There are no issues with how the car behaves. The eml just keeps coming back on each week after a reset. I did a pcm reset today, so I'll see what happens. I'm just at a loss. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted August 26, 2022 Share Posted August 26, 2022 Tool should be ok then.聽 Might be worth checking if you're on the latest update of Forscan. Sounds like there may be a poor connection in the car somewhere but that's just too vague a code to know where to start. You could remove the clocks to check they're plugged in tightly.聽 Could also check the GEM for any dampness or loose plugs. Quote Link to comment Share on other sites More sharing options...
mjt Posted August 27, 2022 Share Posted August 27, 2022 15 hours ago, TomsFocus said: They can also point to a cluster fault, but I'd expect more codes if that was the case It's true that solder joint problems are likely to throw up multiple codes, as happened on ours recently, but that's because the CANbus signals get corrupted. Maybe if it's just one or two pins carrying other signals it might cause a single spurious code. 1 Quote Link to comment Share on other sites More sharing options...
