2012 1.6 mk3 focus battery replacement
ash29109
 Share
And most important. After the battery has been replaced the BMS (battery Monitoring System) needs to be reset.
Also be aware that the new battery needs to have the same specifications (capacity and CCA) as the old one. Installing a higher capacity / CCA battery requires reconfiguration of the direct configuration of the BCM.
Link to comment
6 hours ago, JW1982 said:
And most important. After the Battery has been replaced the BMS (Battery Monitoring System) needs to be reset.
Bummer, I've done exactly that, purchased a higher capacity battery!
Purchased this one
https://www.ebay.co.uk/itm/D21-Car-Battery-12V-Varta-Silver-Dynamic-Sealed-Calcium-5-Yr-Warranty-Type-075-/252646084384?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
 Any ideas how I can reconfigure the BCM?
Link to comment
It can easily be changed using FORScan and a good ELM327(modified) USB lead.
Download FORScan (its free for use on a laptop) : https://forscan.org/download.html
ELM327(modified) USB lead : https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx
Link to comment
Do you know what values in forscan I need to change and where? The car does not have stop/start
Factory battery is:
Silver calcium
Ford brand
500cca
52Ah
The new battery is:
Varta
Sealed calcium
600cca
61Ah
Can it only be done via forscan?
I called my local garage who have non specific ford diagnostic machine which covers all vehicles. Could that do it? Or can it only be done by forscan?
Link to comment
I did not know this! Had my battery replaced by Halfords almost 2 years ago & it occasionally pops up with Low battery on the dash. No idea what was in before or what's in now, still worthwhile me resetting?
Link to comment
To program a different capacity battery on a Focus MK3 there are 2 things that need to be done.
1: Parameter #210 of the CCC (Central Car Configuration) need to be changed in both the BCM and IPC to the correct Hexadecimal code. This can be done with Forscan.
2: Parameter #EE3B of the Direct Configuration of the BCM needs to be changed to the correct value. This can only be done with a diagnostic system that has the ability to change the Direct Configuration. For example UCDS. As far as I am aware Forscan and the Ford IDS/FDRS system do not have this ability (I own all of these systems so I am quite sure about this).
Temporarily fitting the larger capacity battery without changing the configuration is no problem for a short period. The larger capacity battery will just not be fully charged. On the longer term however not being charged sufficiently will drastically reduce the life expectancy of the battery.
You have to make sure that the new battery is the correct type. Most MK3 versions have Start/Stop in combination with a BMS (Battery Monitoring System). This system requires an EFB (Enhanced Flooded Battery).
Link to comment
Thanks, very useful.
My car doesn't have stop start, what does the BMS do?, could I just be done with it and disconnect it?
My current battery is totally flat, need to jump start it, so I've got the new battery which I'm looking to install asap.
Given that I do not have the usb lead, would the manual reset procedure help?
What is the correct manual reset procedure? I've seen so many different ones!
Factory battery is:
Silver calcium
Ford brand
500cca
52Ah
The new battery is:
Varta
Sealed calcium
600cca
61Ah
Link to comment
Just fitted the new battery, disconnected the BMS lead, didn't do the manual BMS reset procedure.
Car started fine, with no warning lights, windows works fine. Just had to re tune radio and clock.
If it's not a big issue I may not bother getting the usb lead and install forscan to set the correct parameters.
What are the pros of cons in having the BMS configured Vs having it disconnected?
Link to comment
Found this on the forscan forum, if the BMS sensor is unplugged
unplug the sensor on the negative battery cable and the pcm will default to a "traditional" charging system and maintain a steady charge voltage of around 14-14.5v
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
