Ashly90 Posted October 24, 2022 Share Posted October 24, 2022 Hi everyone, recently bought a 2018 transit custom. Went to setup CarPlay with the sync 3. When plugged in it came up with the terms and conditions etc which were all accepted but CarPlay never launched and the sync 3 isn’t showing in my CarPlay setting on my iPhone. i also tried updating the sync which is currently 3.0 build 18025. There was an update available but it failed with error LST_ERR05. Anyone have any ideas? thanks in advance Quote Link to comment Share on other sites More sharing options...
unofix Posted October 24, 2022 Share Posted October 24, 2022 That's a common error normally a problem with the way the files have been created on the USB. Have a look at this thread: On 4/8/2021 at 5:48 PM, colinmcg71 said: Hi Geoff, LST_ERR05 means ‘Package not found’ Can you have a look in your SyncMyRide folder. It should look like this - Could you also open up the autoinstall.lst file in notepad, it should look like this - If they both look correct you should be good to go. Quote Link to comment Share on other sites More sharing options...
Ashly90 Posted October 24, 2022 Author Share Posted October 24, 2022 40 minutes ago, unofix said: That's a common error normally a problem with the way the files have been created on the USB. Have a look at this thread: Thanks for the reply. So I’ve been though the auto install file and all files in there match the ones in SyncMyRide, correct spelling, layout etc. is the CarPlay not working due to it needing this update? Quote Link to comment Share on other sites More sharing options...
unofix Posted October 24, 2022 Share Posted October 24, 2022 Very difficult for me to advise on CarPlay as it's not something I've used. The Moderator @alexp999 might be able to give you some pointers. Check list of things: USB stick = 32GB USB = Formatted in ExFat Files UnZipped on the USB stick = Autoinstall - DoNotIndex - and folder called SyncMyRide Inside the SyncMyRide folder there will be several files. Quote Link to comment Share on other sites More sharing options...
Ashly90 Posted October 24, 2022 Author Share Posted October 24, 2022 44 minutes ago, unofix said: Very difficult for me to advise on CarPlay as it's not something I've used. The Moderator @alexp999 might be able to give you some pointers. Check list of things: USB stick = 32GB USB = Formatted in ExFat Files UnZipped on the USB stick = Autoinstall - DoNotIndex - and folder called SyncMyRide Inside the SyncMyRide folder there will be several files. Thanks again for the reply. I am using a 32gb sd card, formatted to exfat and have all the files and folders. I’ve read elsewhere it’s sometimes missing files in the SyncMyRide folder but they all seem to be there going by the Autoinstall file. The only thing I’ve had to do is create the SyncMyRide folder as it didn’t automatically create this, it was done as per the Ford instructions for the update 1 Quote Link to comment Share on other sites More sharing options...
Ashly90 Posted October 28, 2022 Author Share Posted October 28, 2022 Update: now fixed an updated. The update did also fix the CarPlay issues. If anyone else is having LST_ERR05 this may help. I did the download via Mac and exported to the usb stick. All files were correct and in the right place but the update wouldn’t work. I tried today on windows and it worked absolutely fine. Strange but may be worth a go if anyone else is having the same issue 1 Quote Link to comment Share on other sites More sharing options...
Ford Year: 2022
Ford UK Shop for genuine Ford parts & accessoriesJoin the conversation
