Robert M Posted October 25, 2022 Share Posted October 25, 2022 Hi All I am driving Ford EcoSport, after diagnosing I got these results, what can be the cause and how to fix it? TCM (Transmission Control Module) 2 problems exist 1.P07A3:00-68 Transmission Friction Element #A Stuck On Continuous Memory DTCs 2.P286F:00-68 Clutch #A Disengagement Time Performance/Too Slow Continuous Memory DTCs Quote Link to comment Share on other sites More sharing options...
unofix Posted October 25, 2022 Share Posted October 25, 2022 Had similar problems with a EcoSport 1.5 petrol. There seems to be a bit of a reoccurring problem with the wiring harness to the TCM. Take a look at this thread, it is probably worth reading the whole thing from the start but here is a link to the main fault. On 4/15/2022 at 2:04 PM, unofix said: Well @TomsFocus "great minds think alike" So today I decided to investigate the two connectors for the TCM. To gain as much access as possible I fully removed the airbox as you earlier suggested. Then from under the wheel arch I disconnected the 'Red' connector and pulled the harness and connector up in to the engine bay. Take a look at the photos to see what I found........ Quote Link to comment Share on other sites More sharing options...
