Kit7 Posted October 28, 2022 Share Posted October 28, 2022 Help!!! FORD S-MAX 09 Plate. While driving last week the engine malfunction came on with what I think is the traction light. Vehicle started shuddering so pulled over, turned engine off & waited a few moments. Turned ignition & started engine & everything was fine & carried on driving. Cars been driving fine till today, started car this morning & engine malfunction came on with the same skid warning light. I’ve tried it three times during the day & same issue. Any suggestions as to what this is would be much appreciated, my mechanic is currently on holiday so can’t have his input till next week. Cheers. 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted October 28, 2022 Share Posted October 28, 2022 You need to get the DTC using FORScan. Possible problem with the ABS caused by a faulty wheel sensor could be the cause but it is essential that you don't guess and that you get the correct info from FORScan. Download FORScan: https://forscan.org/download.html ELM327(modified) connecting cable: https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx Quote Link to comment Share on other sites More sharing options...
Gleen Posted December 7, 2022 Share Posted December 7, 2022 I had exactly the same problem with my wife's 09 diesel auto s max. The traction control light would come on, putting on diagonally operated brakes, and also various error messages would appear at different times such as 'diesel filter overcharged' .. 'auto transmission requires service' .. and sometimes the engine management light would come on and stay on. Turning the ignition off and back on cleared the fault for a while. Sometimes whilst driving the car felt a bit 'flat' - that was without any warning lights or messages. The fault, apparently, was the turbo. My local workshop cleaned the vanes which has resulted in a car with oomph .. and no warning lights or messages appearing. No new parts were required. No ABS fault was ever found on a diagnostics check. Seemingly one fault ( a dirty turbo, for want of a better description) can cause error messages further down the line.. Quote Link to comment Share on other sites More sharing options...
alanfp Posted December 7, 2022 Share Posted December 7, 2022 1 hour ago, Gleen said: Seemingly one fault ( a dirty turbo, for want of a better description) can cause error messages further down the line.. Certainly true of my car - a clogged fuel filter caused the traction control warning lamp to sometimes light up. Quote Link to comment Share on other sites More sharing options...
Daniel83 Posted May 22, 2023 Share Posted May 22, 2023 did you get this issue fixed? sounds very similar to a p2263 code I kept getting Quote Link to comment Share on other sites More sharing options...
