JRC1 Posted December 1, 2022 Share Posted December 1, 2022 Hi All My partner owns a MK7 1.0 Ecoboost, great car! Anyway, somehow(!) she has clipped something and the whole mirror cap has gone missing - not just the top body coloured cap but also the lower part seems to have gone too inc the indicator element - see pic. My question: is it easier to purchase the cap/bottom element or just buy a second hand full mirror unit off of eBay? After a quick look, the whole unit doesn't appear to be much more than the top cap so I'm thinking this may be the easier route to go down? Further question: If the latter, how do I know the new unit will be the motored version (as these currently auto-fold when the car is locked) and is any programming of the new unit needed, or can I just fit the new unit, plug in and away we go? Any advice would be greatly appreciated 🙂 Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted December 2, 2022 Share Posted December 2, 2022 Yeah just buy a complete 2nd hand mirror and swap the missing parts to yours StephenFord 1 Quote Link to comment Share on other sites More sharing options...
Eric Bloodaxe Posted December 2, 2022 Share Posted December 2, 2022 Not quite clear whether it's just the cap or part of the base that's gone. You can compare from the pic here: https://ultimatestyling.co.uk/ford-fiesta-wing-mirror-door-mirror-passenger-side-lh-ult3967-mm Oddly enough it looks very similar to what happened to me once on a test drive - pigeon flew out of a hedge, straight into the mirror, and did what appears to be identical damage. Quote Link to comment Share on other sites More sharing options...
Bobr Posted December 2, 2022 Share Posted December 2, 2022 If you change the mirror tie a piece of string to the cable before you remove it. You can then use the string to pull the cable of the new mirror through. Otherwise, it's a hell of a job. welshie_miles 1 Quote Link to comment Share on other sites More sharing options...
Doylie Posted December 2, 2022 Share Posted December 2, 2022 If the unit is ok, I'd be tempted to just replace the cap and you can get the indicator lens as a separate as well. Saves you messing about Quote Link to comment Share on other sites More sharing options...
JRC1 Posted December 2, 2022 Author Share Posted December 2, 2022 Quote If the unit is ok, I'd be tempted to just replace the cap and you can get the indicator lens as a separate as well. Saves you messing about Do you know what separate parts I'd need for this though and the part numbers? Is it 3 separate parts? Top body coloured cap, bottom black cap and indicator lense? I think price wise a full unit might be cheaper - £40-60 on eBay. Unless it's an absolute ballache to fit the new unit? Then I could be tempted with what you're saying. Thanks for all of the replies. Does anyone know if I have to look specifically for a MK7.5 unit (car is a 64 plate) or will any MK7 unit fit, even say from 09? Quote Link to comment Share on other sites More sharing options...
unofix Posted December 2, 2022 Share Posted December 2, 2022 Fiesta DOOR mirror parts list: https://ford.7zap.com/en/car/59/code.eu,1.48184,2.5145,6.26248,7.13221,10.32097,12.35745/0/1844/16685/72635/ JRC1 and StephenFord 2 Quote Link to comment Share on other sites More sharing options...
Doylie Posted December 2, 2022 Share Posted December 2, 2022 When I did mine I used these youtube's as a guide, and remember like Bobr says to tie some string to the cable before you remove it (5) Ford Fiesta 2016 mirror indicator bulb and lense replacement - YouTube (5) How to Remove Fiesta Mk7.5 Door Cards / Door Mirror Replacement - Ford Fiesta ST180 - YouTube (5) HOW TO REMOVE AND REPLACE SIDE VIEW MIRROR ON FORD FIESTA MK7 - YouTube JRC1 1 Quote Link to comment Share on other sites More sharing options...
mickywrx Posted December 3, 2022 Share Posted December 3, 2022 If the mirror lens and body are intact, which they look to be, just replace the indicator unit and the mirror cap. It's the easiest and should be the cheapest option. Quote Link to comment Share on other sites More sharing options...
mickywrx Posted December 3, 2022 Share Posted December 3, 2022 On 12/2/2022 at 10:20 AM, JRC1 said: Do you know what separate parts I'd need for this though and the part numbers? Don't buy from Ford. They'll have your pants down, and not use lube. I was quoted circa £200 just for mirror assembly, not including the indicator or cap. Quote Link to comment Share on other sites More sharing options...
JRC1 Posted December 3, 2022 Author Share Posted December 3, 2022 Quote If the mirror lens and body are intact, which they look to be, just replace the indicator unit and the mirror cap. It's the easiest and should be the cheapest option. Don't buy from Ford. They'll have your pants down, and not use lube. I was quoted circa £200 just for mirror assembly, not including the indicator or cap. Thanks for replying. Yeah would no way buy from the stealer. Isn't the lower part of the mirror missing too though, the lower black plastic bit? The bit that covers where the wires are in the above pic... or is that part of the indicator unit? EDIT: see the link here that someone posted above: https://ultimatestyling.co.uk/ford-fiesta-wing-mirror-door-mirror-passenger-side-lh-ult3967-mm The black part below the cap is missing too and that part doesn't seem to be part of the list that was posted above, anyone know what it's called or have a part number? Quote Link to comment Share on other sites More sharing options...
Doylie Posted December 3, 2022 Share Posted December 3, 2022 No thats still there. The indicator lens sits on that and the cap covers everything Quote Link to comment Share on other sites More sharing options...
JRC1 Posted December 3, 2022 Author Share Posted December 3, 2022 Ah ok thanks! So this and this should do it? Quote Link to comment Share on other sites More sharing options...
Doylie Posted December 4, 2022 Share Posted December 4, 2022 It should do. Just check the plastic isn't damaged on the mirror housing where the retaining clips of the cap fit to keep it flush (the last picture of the inside of the cap) The ones along the bottom edge are quite thin but you should be able to stick something on these if they've snapped off. Quote Link to comment Share on other sites More sharing options...
unofix Posted December 4, 2022 Share Posted December 4, 2022 I believe it was 52 years ago since Ford UK last fitted 'Wing Mirrors' as an option. Does anyone know, was the 1970 Capri the last to have them fitted or were they available on other models after that ? eddie eastwood 1 Quote Link to comment Share on other sites More sharing options...
mickywrx Posted December 4, 2022 Share Posted December 4, 2022 5 hours ago, unofix said: I believe it was 52 years ago since Ford UK last fitted 'Wing Mirrors' as an option. Does anyone know, was the 1970 Capri the last to have them fitted or were they available on other models after that ? No idea, but, we've got a Ford Zephyr at work. Belongs to my gaffers dad, awkward thing to drive. Mirrors actually mounted on the wings, and column shift. unofix 1 Quote Link to comment Share on other sites More sharing options...
JRC1 Posted December 5, 2022 Author Share Posted December 5, 2022 On 12/4/2022 at 1:13 PM, Doylie said: It should do. Just check the plastic isn't damaged on the mirror housing where the retaining clips of the cap fit to keep it flush (the last picture of the inside of the cap) The ones along the bottom edge are quite thin but you should be able to stick something on these if they've snapped off. I've taken more of a close up pic - see the two elements I've circled in yellow, looks like these have snapped to me. Does this lean towards a whole new unit being the better approach or do you still think a new cap will fit on here ok based upon your knowledge/experience? Thank you Quote Link to comment Share on other sites More sharing options...
Doylie Posted December 5, 2022 Share Posted December 5, 2022 From the donor one I’ve got in the loft it looks like the bit that’s snapped in the middle of your pic holds the indicator lens in place The clips for the cap are on the left of your pic so the damage on the right might not be significant Quote Link to comment Share on other sites More sharing options...
JRC1 Posted December 5, 2022 Author Share Posted December 5, 2022 1 hour ago, Doylie said: From the donor one I’ve got in the loft it looks like the bit that’s snapped in the middle of your pic holds the indicator lens in place The clips for the cap are on the left of your pic so the damage on the right might not be significant Thank you for this - really helpful. As there's not a huge amount in it cost wise, I think I'm going to buy a whole new mirror and that way I get best of both worlds. I can first try to fit just the cap and indicator lense from the new mirror to the damaged one and if that doesn't work, I can then just fit the whole unit. Assume it's relatively easy to pop the cap and indicator lense off of a donor unit? Quote Link to comment Share on other sites More sharing options...
Doylie Posted December 5, 2022 Share Posted December 5, 2022 its pretty straight forward. just watch the videos posted earlier so you know what to do. Quote Link to comment Share on other sites More sharing options...
