ESC service light
ESC service light came on with various other warning lights ,park pilot and hill start.
been to my local garage who reset and checked the car over all seems fine but the lights defaults came back on.
can anyone help? What is a ESC service ?
Very probably a faulty ABS wheel sensor.
Generic code readers are not good at reading Ford specific DTC's.
Get a laptop and download FORScan. On a 2017 model I would recommend using the new vLinker FS cable but you could use the cheaper ELM327(modified) lead from TunnelRat Electronics.
Using FORScan you will be able to see if there is a problem with the ABS wheel sensors (and even which one).
FORScan: https://forscan.org/download.html
vLinker FS cable: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP/ref=asc_df_B0952P4MLP/?tag=googshopuk-21&linkCode=df0&hvadid=534732308385&hvpos=&hvnetw=g&hvrand=14490452733772428362&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006688&hvtargid=pla-1430824679036&psc=1
OR
ELM327(modified) lead: https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx
