Indicators
Hi guys/ girls,  can anyone help, I've lost all use of my indicators, they don't blink when alarm gets set on or off, they don't work off the indicator stork or off the hazard switch,I was told it could possibly be the hazard button could be at fault, bought new one but with no joy, all fuses are OK.. What the hell is the issue, please help
So you've checked fuses 2.13 and 2.14? If there ok could actually be the electronic flasher control module.
Edit, the fuses on my wiring diagram show 2.13 and 2.14, I just cross-reference the actual fuse box layout and it's fuse 9 and 10.
If there ok. Then i would be looking at the flasher relay. That's buried up high somewhere around the back of the instrument cluster.
Should look like this
https://www.ebay.co.uk/itm/195444119877?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=1C8Laa2cRji&sssrc=2349624&ssuid=c-tOKX7vROe&var=&widget_ver=artemis&media=COPY
It's got a major case of BMW disease, there is no known cure I'm afraid.
Well there clearly is a cure... Why answer like that... Stupid
Well it's good to see you have had the humor bypass operation. As far as there clearly is answer, yes there is and @iantt has probably already told you what it is.
Merry Christmas 🎉
