scotty79 Posted February 8, 2023 Share Posted February 8, 2023 anyone else had this alert? got it scanned and was told it was one of the sensors but there’s 3 and he doesn’t know which one it is and doesn’t know how to narrow it down to which one it could be, he’s also told me he’s waiting on a call back from someone he knows from ford to help him out but every time i speak to him he’s not heard nothing back lookimg for a bit more insight and info if any has any, thanks Quote Link to comment Share on other sites More sharing options...
Tizer Posted February 8, 2023 Share Posted February 8, 2023 That alert is just an alert, no one can do a proper diagnosis from that alone, the proper codes need to be read first and Live Data as well as further Inspection and testing from there. FORScan can do the necessary diagnostic work as can other professional Scanners. If the person looking at your car is not suitably equipped then they might get lucky or not. 1 Quote Link to comment Share on other sites More sharing options...
scotty79 Posted February 8, 2023 Author Share Posted February 8, 2023 it was scanned at a garage, i can’t remember exactly what he said the codes said but it was to do with sensors, that’s when he said there’s 3 of them he just didn’t know exactly which one of the three it was would forscan or even a better code reader to what he probably has tell better which one it exactly is? 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted February 8, 2023 Share Posted February 8, 2023 I wouldn't bother with the garage you used. If a DTC is stored , then it really should narrow down the sensor. Also data logging the sensors should show a dodgy sensor. You need to use a garage who know what there doing. 2 1 Quote Link to comment Share on other sites More sharing options...
Tizer Posted February 8, 2023 Share Posted February 8, 2023 There will be a few Sensors on the DPF/CAT Assembly but I doubt if 3 of them are Temperature ones. I'm not familiar with the version of Engine on your car but you may be able to find an online Parts Catalogue or Workshop Manual online that has an exploded view of the DPF/CAT Assembly to see what is what. If the Alert in Ford Pass is correct and it is a Temperature Sensor then as well as getting the correct Code you should be able to see a Live Readout of what temperature the PCM is seeing from the Sensor(s). Even if there are 3 then if one is showing no reading then it would not be difficult to work out which one it was by disconnecting one at a time. If it/one of them is showing no or a default reading then either the Sensor is faulty, there is a Wiring fault or a PCM fault. I've just seen Ian's reply and agree with it. Quote Link to comment Share on other sites More sharing options...
scotty79 Posted February 8, 2023 Author Share Posted February 8, 2023 thanks for the replies guys, should have stated it’s a st-line x 1.5l diesel can see me taking it back to arnold clark and having to just fork out the money to them Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 8, 2023 Share Posted February 8, 2023 Two temp sensors - one pre cat, one post cat. And an O2 (lambda) sensor right at the top elbow. 3 1 Quote Link to comment Share on other sites More sharing options...
Tizer Posted February 8, 2023 Share Posted February 8, 2023 11 minutes ago, TomsFocus said: Two temp sensors - one pre cat, one post cat. And an O2 (lambda) sensor right at the top elbow. Shouldn't be difficult to work out what one is faulty then without disconnecting one. The first one is probably called the Exhaust Raw Temperature or something similar and the second one the CAT Temperature or something like that. 2 Quote Link to comment Share on other sites More sharing options...
scotty79 Posted February 8, 2023 Author Share Posted February 8, 2023 is the dpf/cat at the front of the engine bay? i know there’s three sensors on that which i would have thought would be easy to check and replace which one is faulty Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 9, 2023 Share Posted February 9, 2023 13 hours ago, scotty79 said: is the dpf/cat at the front of the engine bay? i know there’s three sensors on that which i would have thought would be easy to check and replace which one is faulty Yes that's right. Very easy to access on this engine. 1 Quote Link to comment Share on other sites More sharing options...
