GERNICK Posted February 17, 2023 Share Posted February 17, 2023 My dashboard direction indicator light is flashing at least double the speed of the exterior lamp indicators. I have checked the external indicator flashing speed which is normal, and all bulbs are working. It's rather annoying as I'm worried a bulb may have blown, but there's nothing obvious. Any clues? Quote Link to comment Share on other sites More sharing options...
unofix Posted February 17, 2023 Share Posted February 17, 2023 Have you replaced any of the lamps with LED's ? Are the side repeater indicators (mounted on the mirrors) working ? When you use the Hazard lights does the warning lights flash at the correct speed ? Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted February 17, 2023 Share Posted February 17, 2023 As unofix has mentioned, ensure non of the bulbs are LEDs and no bulbs have popped, including side repeaters Quote Link to comment Share on other sites More sharing options...
Jimpster Posted February 17, 2023 Share Posted February 17, 2023 its called hyperflash caused by fitting incompatile non canbus bulbs Quote Link to comment Share on other sites More sharing options...
GERNICK Posted February 20, 2023 Author Share Posted February 20, 2023 Thank you all. The Warning/hazzard lights flash at the correct rate. All bulbs were as I received the vehicle, so no idea if any had ever been replaced. It's only just started after I charged the battery! Quote Link to comment Share on other sites More sharing options...
unofix Posted February 20, 2023 Share Posted February 20, 2023 1 hour ago, GERNICK said: It's only just started after I charged the battery! Not that it should make any real difference to how the indicator warning lights behave, but did you reset the BMS after you changed the battery ? Quote Link to comment Share on other sites More sharing options...
GERNICK Posted March 5, 2023 Author Share Posted March 5, 2023 Me being ignorant of the acronym, what is the BMS please? Thanks Tim Quote Link to comment Share on other sites More sharing options...
alexp999 Posted March 5, 2023 Share Posted March 5, 2023 battery Monitoring System Quote Link to comment Share on other sites More sharing options...
GERNICK Posted March 8, 2023 Author Share Posted March 8, 2023 tHANK YOU. i WILL CHECK !! TIM Quote Link to comment Share on other sites More sharing options...
GERNICK Posted May 27, 2023 Author Share Posted May 27, 2023 The external indicators are flashing at the correct speed, and the dash panel at twice the speed ! Quote Link to comment Share on other sites More sharing options...
unofix Posted May 27, 2023 Share Posted May 27, 2023 Has the vehicle had a towbar fitted in the past that has now been removed ? Hyper flash of the indicator warning lights on the instrument cluster is a warning that the trailer module is faulty or disconnected. Quote Link to comment Share on other sites More sharing options...
RL123 Posted May 28, 2023 Share Posted May 28, 2023 May be worth checking Fusebox and the relays. Just a thought Quote Link to comment Share on other sites More sharing options...
unofix Posted May 28, 2023 Share Posted May 28, 2023 54 minutes ago, RL123 said: worth checking Fusebox and the relays. Indicators are controlled by the Body Control Module, there are no relays or flasher units just a computer 😉 Quote Link to comment Share on other sites More sharing options...
GERNICK Posted May 29, 2023 Author Share Posted May 29, 2023 Yes, a towbar was fitted 10 months ago, and I put a pin convertor into the EU standard 13 pin to 7 pin socket Quote Link to comment Share on other sites More sharing options...
unofix Posted May 29, 2023 Share Posted May 29, 2023 Your Ford trailer module software is either not configured or is has been incorrectly configured. The BCM needs to know that the vehicle now has a towbar and that a trailer module is connected. 2 Quote Link to comment Share on other sites More sharing options...
