Jason87 Posted February 18, 2023 Share Posted February 18, 2023 On my mk2.5, one of the washer jets out of the 2 jets on the passenger side isn’t working. I pushed a pin on the hole so it’s not blocked but I noticed the pin goes right in but on the jet next to it that works, the pin doesn’t go in as deep and hits something. I took the Bonnet lining off but can’t see how to view the jets themselves, only the pipe that goes to it. Is there anything I can do easily? Quote Link to comment Share on other sites More sharing options...
StephenFord Posted February 18, 2023 Share Posted February 18, 2023 2 hours ago, Jason87 said: On my mk2.5, one of the washer jets out of the 2 jets on the passenger side isn’t working. I pushed a pin on the hole so it’s not blocked but I noticed the pin goes right in but on the jet next to it that works, the pin doesn’t go in as deep and hits something. I took the Bonnet lining off but can’t see how to view the jets themselves, only the pipe that goes to it. Is there anything I can do easily? Remove the jet, it's only a push it. If you have access to a compressed air line. blow some air in it, if not, put it on your lips tight, and blow real hard... Quote Link to comment Share on other sites More sharing options...
Jason87 Posted February 18, 2023 Author Share Posted February 18, 2023 19 minutes ago, StephenFord said: Remove the jet, it's only a push it. If you have access to a compressed air line. blow some air in it, if not, put it on your lips tight, and blow real hard.. Quote Link to comment Share on other sites More sharing options...
Jason87 Posted February 18, 2023 Author Share Posted February 18, 2023 Do i remove it under the bonnet? I’ll have to have another look, didn’t look like it would come out easy Quote Link to comment Share on other sites More sharing options...
StephenFord Posted February 18, 2023 Share Posted February 18, 2023 55 minutes ago, Jason87 said: Do i remove it under the bonnet? I’ll have to have another look, didn’t look like it would come out easy Yes, push upwards from under the bonnet, if they have never been removed, may be a bit stiff with years of crud holding it in... 1 Quote Link to comment Share on other sites More sharing options...
Jason87 Posted February 19, 2023 Author Share Posted February 19, 2023 All fixed, thanks! 1 Quote Link to comment Share on other sites More sharing options...
