How do heaters work in all electric vehicles?
VFR800
Β Share
Do they utilize the battery cooling system or is it glowing wire between two posts type affair, like what ya granny had!!! πŸ˜‰
Link to comment
Yes, it is indeed 'resistive heating' so it helps to run the battery flat a bit quicker.
  • Like 1
Link to comment
It depends, a lot of cheaper cars use resistive heaters. (Like the portable fan heaters you can get for home).
It's much better when they are fitted with heat pumps (sometimes it is an optional extra) as it's much more efficient and can be used both ways to act as A/C.
IMO it should be mandatory for them to use heat pumps. They already have most of what's needed by fitting an A/C system.
  • Like 1
Link to comment
I often forget most people have gas heating at home.Β  Glowing wires is still the norm for those us with all electric properties! :laugh:Β
Worth noting that it's probably more effective to use a heated seat or steering wheel in an EV than it is to blow hot air out of multiple vents around the cabin.
  • Like 2
Link to comment
In theory a heat pump should be a no-brainer for an EV but it's not as simple as reversing the flow of refrigerant. For a heater you'd need an evaporator at the front and a condenser in the cabin with some means of switching the pipe connections. It'd probably be easier to just fit a separate system with it's own pump.
Link to comment
They manage a single system with in home air to air heat pumps that can worth in both directions. Should just be able to downscale for the car.
Link to comment
If only they could develop some kind of system that could use the waste energy from the propulsion engine into cabin heat, with a fully fledged control system on heating power & temperature... oh... wait a minute... LOL
  • Haha 4
Link to comment
Yeah, that's the electric car for you.Β
Any waste heat is indeed sent to the cabin to warm up the electric car. Your so knowledgeable about electric cars already. 🀣🀣
Only downside is the anoying way the cabin warms up while I'm having my breakfast. Then no scrapping of windows when icy and shivering while the car takes 10 miles to warm up. 🀣🀣🀣🀣🀣
  • Like 1
  • Haha 1
Link to comment
6 hours ago, TomsFocus said:
Β
Or use those as well as normal heater. Toasty warm.Β
  • Like 1
Link to comment
Both. From cold the PTC heater ( glowing wire)instantly warms the cabin up , then as you drive theΒ  excess heat generated from motor, battery,modules is piped into the cabin heater system also. The PTC heater then reduces with the waste heat in the cooling system keeping the cabin to temp. Therefore the electricity required is reduced significantly on your journey if cold outside.Β
From cold in winterΒ  the range reduces by 10 miles initially then as you drive that reduces to 3 miles reduction. Winter temps hasn't really taken much of a hit on my consumption figures as I thought it might. There are electric vehicles less efficient than mine that are not good in winter( stelantis group cars don't do well)
  • Like 2
Link to comment
Γ— Β  Pasted as rich text. Β Β Paste as plain text instead
Β  Only 75 emoji are allowed.
Γ— Β  Your link has been automatically embedded. Β Β Display as a link instead
Γ— Β  Your previous content has been restored. Β Β Clear editor
Γ— Β  You cannot paste images directly. Upload or insert images from URL.
Β Share
Γ—
Γ—
  • Create New...
Forums
News
Membership
