RobLeeds Posted March 12 Share Posted March 12 Hi I’m fitting a kill switch to my mk4, back in the day a mechanic friend of mine used to recommend taking it from one of the wires feeding the coil and running wire to a hidden location in the car, I’ve heard of fuel pump or battery ones too. Has anybody fit one to their classic and which did you go for? Just interested in other takes on it, Rob Quote Link to comment Share on other sites More sharing options...
Paulkp Posted March 12 Share Posted March 12 Cars that have electric fuel pumps tend to be fitted with a "Shock Detection" switch that cut off the supply to the fuel pump. Or are you thinking of a theft deterrent type switch hidden away somewhere ? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 12 Share Posted March 12 My personal preference would be a clear visual deterrent on a retro/classic car. Any damage done to gain entry is likely to be expensive with parts being less common now. Big yellow Disklok or similar. 2 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 12 Share Posted March 12 4 minutes ago, TomsFocus said: Big yellow Disklok or similar. Or better still a big Chrome Disklok, but they are rare and not even photos of them exist.... or do they ?? @StephenFord might know 🤔 2 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted March 12 Share Posted March 12 7 minutes ago, unofix said: Or better still a big Chrome Disklok, but they are rare and not even photos of them exist.... or do they ?? @StephenFord might know 🤔 You just made me giggle! LOL 1 1 Quote Link to comment Share on other sites More sharing options...
RobLeeds Posted March 12 Author Share Posted March 12 Yes I was meaning a hidden switch somewhere as extra protection, I have a disclock already, but not chrome I’m afraid 🙂 1 Quote Link to comment Share on other sites More sharing options...
Paulkp Posted March 13 Share Posted March 13 So if KE - Jetronic, the fuel pump is an obvious choice. If the Fuel pump is fed by a relay or unique fuse then you could break the RELAY (not ign) coil supply, or the actual supply. I'd have a good look at both the schematic, and how you can physically embody it. The best place to hide a switch, might be in full view. Quote Link to comment Share on other sites More sharing options...
RyboNashy02 Posted March 13 Share Posted March 13 20 hours ago, RobLeeds said: Hi I’m fitting a kill switch to my mk4, back in the day a mechanic friend of mine used to recommend taking it from one of the wires feeding the coil and running wire to a hidden location in the car, I’ve heard of fuel pump or battery ones too. Has anybody fit one to their classic and which did you go for? Just interested in other takes on it, Rob On my old 206, I had mine connected to the fuel pump. Quite easy to do as you can just splice it in under your steering wheel! I had hidden the switch under the leather on my gear stick, no one looks there!!!! Quote Link to comment Share on other sites More sharing options...
StephenFord Posted March 13 Share Posted March 13 10 minutes ago, Paulkp said: ...The best place to hide a switch, might be in full view. Yep, if I had one, I'd put it on the dash... 2 Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted March 13 Share Posted March 13 Take the main HT lead off from the coil, when you park it. Unless they carry one around with them, it's not going anywhere 1 Quote Link to comment Share on other sites More sharing options...
Wino Posted March 13 Share Posted March 13 IIRC did someone on here ( @unofix) fit a kill switch relating to the fuel supply which could be activated by their mobile phone ? Quote Link to comment Share on other sites More sharing options...
unofix Posted March 13 Share Posted March 13 Yes, kind of 🤔 I have a tracker fitted on my car which has a remotely operated output. So I've wired the output to a relay that cuts the electrical supply to the fuel pump. I can activate the tracker output from either my phone or using a computer via the tracker website. The only thing is on my diesel for some reason with the fuel pump supply off the car still manages to run and can get nearly up to 20 mph but that's as fast as it will go. On the rest of the family vehicles, some diesel and some petrol I've managed to kill them stone dead, but not my own 🙄 Quote Link to comment Share on other sites More sharing options...
Wino Posted March 13 Share Posted March 13 18 minutes ago, unofix said: Yes, kind of 🤔 I have a tracker fitted on my car which has a remotely operated output. So I've wired the output to a relay that cuts the electrical supply to the fuel pump. I can activate the tracker output from either my phone or using a computer via the tracker website. The only thing is on my diesel for some reason with the fuel pump supply off the car still manages to run and can get nearly up to 20 mph but that's as fast as it will go. On the rest of the family vehicles, some diesel and some petrol I've managed to kill them stone dead, but not my own 🙄 How weird, Is there a particular Ford design reason why it won't cut the fuel supply off completely ? Quote Link to comment Share on other sites More sharing options...
unofix Posted March 13 Share Posted March 13 Just now, Wino said: why it won't cut the fuel supply off completely ? no idea, it just seems as if the engine is able to pull enough fuel through with out the pump !! Still, given the maximum speed it will do is 20mph it is probably enough for them to just abandon it, or it would be a very slow police chase 🤣 1 Quote Link to comment Share on other sites More sharing options...
Paulkp Posted March 13 Share Posted March 13 Not that I know about such things, but these days, stolen cars are just moved to a nearby out of sight position, just in case they do have a tracker, then collected later ? 1 Quote Link to comment Share on other sites More sharing options...
RobLeeds Posted March 13 Author Share Posted March 13 Thanks for the replies everyone, sounds like the fuel pump is most people’s favourite, I’ve not looked into a tracker, may do.back in the eighties I had a few mk3s and always had a hidden switch taken from the coil, il look into some of the suggestions on here. 1 Quote Link to comment Share on other sites More sharing options...
Wino Posted March 13 Share Posted March 13 53 minutes ago, RobLeeds said: Thanks for the replies everyone, sounds like the fuel pump is most people’s favourite, I’ve not looked into a tracker, may do.back in the eighties I had a few mk3s and always had a hidden switch taken from the coil, il look into some of the suggestions on here. I wouldn't be bothered with a tracker tbh as Ford Pass locates the car as it stands. Also an old mobile phone can be placed in the car with its location switched on as a secondary device. You could also add an apple tag to that list as alternatives. 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 13 Share Posted March 13 7 minutes ago, Wino said: I wouldn't be bothered with a tracker tbh as Ford Pass locates the car as it stands. Well I never knew they had that back in the days of 1989 Escorts 🤣 An apple airtag might be an easy option 👍 Quote Link to comment Share on other sites More sharing options...
Wino Posted March 13 Share Posted March 13 7 minutes ago, unofix said: Well I never knew they had that back in the days of 1989 Escorts 🤣 An apple airtag might be an easy option 👍 LOL, too much Vino and only on day 1 of 12 🤣 1 Quote Link to comment Share on other sites More sharing options...
Ian Keys Posted March 14 Share Posted March 14 Hi what you need to do is find a wire that runs down the drivers side of the car which goes from the fuse box to the fuel pump. This is usually a black wire that goes under the carpet close to the sill. When your 100% certain youve found that wire cut it under the carpet and put each end of that wire into a switch that has on or off and by switching this off your fuel pump wont run and nobody can start the car. Just switch it on when you use the car. You could locate the switch close to the backseat under the carpet snd even have a small slit to get to it when you want. Good luck. 1 Quote Link to comment Share on other sites More sharing options...
RobLeeds Posted March 14 Author Share Posted March 14 4 hours ago, Ian Keys said: Hi what you need to do is find a wire that runs down the drivers side of the car which goes from the fuse box to the fuel pump. This is usually a black wire that goes under the carpet close to the sill. When your 100% certain youve found that wire cut it under the carpet and put each end of that wire into a switch that has on or off and by switching this off your fuel pump wont run and nobody can start the car. Just switch it on when you use the car. You could locate the switch close to the backseat under the carpet snd even have a small slit to get to it when you want. Good luck. Thanks Ian that’s very helpful I will have a look into that, I would certainly prefer something along those lines, Rob Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted March 15 Share Posted March 15 Why are we all talking about fuel pumps on a MK4 1.6 Ghia? It's got a carb??? Pull the HT lead off or take the rotor arm out of the dizzy cap Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 15 Share Posted March 15 Having to lift the bonnet every time you lock or unlock would be annoying tbh. It's also likely to snap the bonnet cable eventually as they won't be designed for so much use. 1 Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted March 15 Share Posted March 15 Maybe, but you can't fit a kill switch on a mechanical fuel pump 1 Quote Link to comment Share on other sites More sharing options...
