glosrobbo369 Posted March 21, 2023 Share Posted March 21, 2023 Hi, I’m new to the forum and am after some advice. I intermittently get rain water accumulating in the spare tyre well of my 2010 Focus. It’s got to be a leaking seal as the water gets in when it’s parked rather than driving and I think it’s coming in somewhere on the drivers (right) side. Has anyone got any ideas where I should start looking? Thanks Steve Quote Link to comment Share on other sites More sharing options...
StephenFord Posted March 21, 2023 Share Posted March 21, 2023 11 minutes ago, glosrobbo369 said: Hi, I’m new to the forum and am after some advice. I intermittently get rain water accumulating in the spare tyre well of my 2010 Focus. It’s got to be a leaking seal as the water gets in when it’s parked rather than driving and I think it’s coming in somewhere on the drivers (right) side. Has anyone got any ideas where I should start looking? Thanks Steve Remove rear light cluster, and clean up the years of accumulated crud! 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 21, 2023 Share Posted March 21, 2023 Water in the boot of a Mk2 Focus ??? I thought a Jacuzzi was a standard fitment on these 🤣 3 Quote Link to comment Share on other sites More sharing options...
rd457 Posted March 21, 2023 Share Posted March 21, 2023 To add to Stephen's advice, as unofix alludes to this is a common problem on the Mk2, people have tried to solve this before (including a relative of mine) by adding sealant in spots around the light cluster, but failed to fix the problem. However I recently found a video on youtube that was enlightening; someone with a huge amount of patience found (very surprisingly) on their Mk2 that water was getting sucked in at the top edge of the indentation where the boot hinge is located. I watched him prove it and I was convinced that they were correct. It's rather unintuitive, you'd think that water flowing over this from on top would just simply fall into the gutter, but no, there's a seam in the metal there and at least in this one case there must be a draft of air flowing through it or something because this person demonstrated that if you have patience and keep pooring water over that area, eventually you'd get some making it's way into the boot. I've yet to try putting some sealant in that spot on my relative's car, I've not had the chance yet. Oh, another spot to look at apparently is a seam under the "plastic trim on the roof", by which I presume they mean the plastic strips along the edges with the fixings for a roof rack.. Let me see if I can find that video... Ah here it is: And here is the follow-up: 1 1 Quote Link to comment Share on other sites More sharing options...
troy45 Posted March 21, 2023 Share Posted March 21, 2023 The foam seals on the rear light inserts can rot away, seen this first hand even after replacing the inserts with new ones. So it helps to add some sealant to try and beef up these seals plus maybe guide water away too. I sealed up my tailgate hinge pockets while trying to fix a leak in the boot but eventually found it was coming in through a gap in the sealer at bottom corner of the boot on the left hand side, virtually above the rear bumper. There is sealer buried in there from the factory but it’s a blind process to apply it and they obviously didn’t do a great job of it. Fixed with some silicone sealer best I could and it’s not leaked since. Quote Link to comment Share on other sites More sharing options...
