Mickeyluv Posted March 24 Share Posted March 24 I need to change a front drop link on my ST-Line and don't have a factory jack (it doesn't come with one). Where's a good place to raise it with a trolley jack to get the wheel off? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 24 Share Posted March 24 There should still be a strengthened section under the sill if you look carefully. If not, then jacking up under the front subframe is fine. Quote Link to comment Share on other sites More sharing options...
Mickeyluv Posted March 24 Author Share Posted March 24 Thanks for the replies. I ended up placing a wooden block under the subframe and jacked it from there. I need to make up a pad to jack it on the the seam to avoid damage, as my jack has a rather severe serrated head. I've done this for my Skoda Yeti out of 1 1/2" thick nylon but it doesn't fit the Ecosport due to a projection on this car to locate the factory jack. A side project for another day. All done though - it only took a few minutes to change the link once the wheel was off. 1 Quote Link to comment Share on other sites More sharing options...
