Ford Escort 1.8 1996 fuse box
The chances of finding the exact match is very slim.
The main core part number 96AG14A073 is what you need to search for.
The second last letter is basically defining how the fuse box was populated, i.e. which relays and which fuses were fitted, these changed depending on engine and trim level. The last letter is simply the revision/batch and would change if even something as simple as a fuse value was altered during production of the unit.
You could most probably use a 96AG14A073DA which is the same box but you would need to fit the relays and fuses suitable to your vehicle. Should be simple you have the original to copy from
  • Like 1
Link to comment
Thanks Unofix - very helpful!
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
