mark.diver Posted May 11 Share Posted May 11 I've got a 2009 2.0 Lt S max diesel that has just devolped a strange fault with the electronic parking brake. When you stop the car and park up the brake comes on as normal and warning light light illuminates on the dash, normally this light goes out after a while but I've noticed it is now staying on all the time, it was still on when I went back to the car this morning. Worried that this going to drain the battery, any ideas where I should looking for the fault? Thank you. Quote Link to comment Share on other sites More sharing options...
unofix Posted May 11 Share Posted May 11 57 minutes ago, mark.diver said: Worried that this going to drain the battery That's not something to worry about. It would take more than a year for the little LED warning light to run the battery flat. More concerning is the fact the light is on when it shouldn't be. It is not just an indication of the parking brake but also an indication of a brake system fault. When were the rear brakes last serviced ? It may require new pads. Quote Link to comment Share on other sites More sharing options...
mark.diver Posted May 11 Author Share Posted May 11 4 hours ago, unofix said: That's not something to worry about. It would take more than a year for the little LED warning light to run the battery flat. More concerning is the fact the light is on when it shouldn't be. It is not just an indication of the parking brake but also an indication of a brake system fault. When were the rear brakes last serviced ? It may require new pads. Thanks for the reply. I don't know when the rear brakes where last looked at, only just got the vehicle. The light goes out once you pull away and behaves normally whilst driving, just wondering why it stays on once the vehicle is parked with ignition off, would low pads cause that? Quote Link to comment Share on other sites More sharing options...
unofix Posted May 11 Share Posted May 11 1 hour ago, mark.diver said: would low pads cause that? Quite possibly if the parking brake is not able to apply full pressure to the pads because they have worn down. Quote Link to comment Share on other sites More sharing options...
mark.diver Posted May 11 Author Share Posted May 11 29 minutes ago, unofix said: Quite possibly if the parking brake is not able to apply full pressure to the pads because they have worn down. Ok thank you, I'll have a look at the pads and see what they are like. Quote Link to comment Share on other sites More sharing options...
