CursedBones Posted May 25, 2023 Share Posted May 25, 2023 ---------------------------------------------------------- -Ford Fiesta Zetec JA8 08-13 ---------------------------------------------------------- -Remove the 2 caps covering the windscreen wiper arm nuts -Remove both of the windscreen wiper arm nuts with a 12mm socket -Make a small mark on the window wiper arm and on the mounting point so that you can refit the wiper in the exact same position on reassembly (Use a marker or a Stanley knife) -Fold both of the wipers up off the window and then rock them back and forth to free them from the splines -Position each wiper arm onto the car (line up the mark on the arms with the mark on the receiving end) -Tighten both of the 12mm nuts for the wiper arms @ 20Nm -Reinstall both of the caps ---------------------------------------------------------- Useful sources: FORD FIESTA WINDSHIELD WIPER ARM REMOVAL REPLACEMENT MK7 ST ---------------------------------------------------------- Quote Link to comment Share on other sites More sharing options...
