briggo Posted June 17 Share Posted June 17 I can’t find a way of changing the speed display on my 2023 Puma ST (Sync 3) from mph to kph for Continental driving. I’ve just picked up a motorway speeding ticket in France for failing to calculate accurately in my head the conversion of 90 kph to mph (55.4 I was doing 62). Quote Link to comment Share on other sites More sharing options...
unofix Posted June 17 Share Posted June 17 Assuming you have the digital instrument cluster then it's a simple thing to change. Press the menu button on the steering wheel (3 lines right hand side) Go into display settings and then select speedometer kph instead of mph. See owners handbook for details. https://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?countryCode=USA&languageCode=EN&Uid=G2110201&ProcUid=G2110207&div=f&variantid=7589&vFilteringEnabled=True&userMarket=GBR&buildtype=web 1 Quote Link to comment Share on other sites More sharing options...
Eric Bloodaxe Posted June 17 Share Posted June 17 Similar procedure on Mk 8.5 Fiestas with digital instruments. The screen doesn't display the full menu at once so you need to scroll up/down to see it all. I found the scroll function seems a bit "laggy" (on mine at least) so it took a while to find it. Slightly confusingly the measurement units for the trip display - mpg to litres/km etc - are changed via the Sync screen. 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted June 17 Share Posted June 17 13 minutes ago, Eric Bloodaxe said: Similar procedure on Mk 8.5 Fiestas with digital instruments. The screen doesn't display the full menu at once so you need to scroll up/down to see it all. I found the scroll function seems a bit "laggy" (on mine at least) so it took a while to find it. Digital dash was frustratingly laggy on the Mk4 Focus as well. Shame they don't appear to have improved it since. 1 Quote Link to comment Share on other sites More sharing options...
