mickter Posted July 8 Share Posted July 8 Just bought a 2012 C-Max 1.6 tdci, 2 questions. Tried radio without engine running and it goes off after about 10min, tried with ign off,in aux ,but won`t stay on. once it goes off pressing on/off button does not do anything. both 2016 models I had before used to stay on for 1hr. also wiper doesn`t do single wipe without ign on, did no later model. All help appreciated. Cheers Mick. Quote Link to comment Share on other sites More sharing options...
unofix Posted July 8 Share Posted July 8 13 minutes ago, mickter said: Tried radio without engine running and it goes off after about 10min That's correct. Depends on the state of charge of your battery, and the battery saver relay / body control module programming. Quote Link to comment Share on other sites More sharing options...
mickter Posted July 8 Author Share Posted July 8 1 hour ago, unofix said: That's correct. Depends on the state of charge of your battery, and the battery saver relay / body control module programming. The book says it should stay on for an hour,the battery is fully charged, it`s not a stop/start version. Quote Link to comment Share on other sites More sharing options...
mickter Posted July 8 Author Share Posted July 8 1 hour ago, mickter said: The book says it should stay on for an hour,the battery is fully charged, it`s not a stop/start version. Will stick it on charge and get battery checked 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted July 8 Share Posted July 8 1 hour ago, mickter said: The book says it should stay on for an hour, The magic words are "up to" 😉 1 Quote Link to comment Share on other sites More sharing options...
alanfp Posted July 8 Share Posted July 8 4 hours ago, mickter said: wiper doesn`t do single wipe without ign on, I don't think I've known of a car where the wipers will work without ign on, so I wouldn't worry much about that one (unless you're saying that they will do continuous wiping without the ign on, in which I would worry a little). Quote Link to comment Share on other sites More sharing options...
mickter Posted July 9 Author Share Posted July 9 My 16 plate did. Going to fit new battery as I think the one fitted is original ,10 years old, will I need radio code and if so where do I get it from. Cheers Mick. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted July 9 Share Posted July 9 36 minutes ago, mickter said: will I need radio code and if so where do I get it from. No radio codes on these. You will need to reset the one-touch windows after fitting a new battery. 1 Quote Link to comment Share on other sites More sharing options...
mickter Posted July 10 Author Share Posted July 10 Hi all, Just replaced battery, now outside temp reads -40,and ice warning on dash is red. can this be reset. TIA Mick. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted July 10 Share Posted July 10 It can't be reset but should sort itself out. 1 Quote Link to comment Share on other sites More sharing options...
mickter Posted July 12 Author Share Posted July 12 All good temp now reads as should,radio stays on. Thanks Mick. 1 Quote Link to comment Share on other sites More sharing options...
