Fusion Misfire
Big Bob
Hi folks, I have a bit of a misfire on my 04 Fusion 1.4 petrol. It feels like a spark plug but I've replaced them a couple of months ago.
I've done the dash board thing & got a DTC d262. I've googled the code but every link seems to give a different response, [none give a cure]
Ranging from #1 injector to message not received to the code means nothing at all.
Does any one know, or have had this code & then actually cured the fault.
Your help would be greatly appreciated. TIA
Rob
D262 is the same as U1262. This is a code that relates to what happens on the communication on the vehicle,it just shows that some data is missing when being received by the PCM. as for the misfire i would look towards a coil pack.
Thanks for the quick response, is there any way to check the coil pack or is it a swap it & see?
some garages will have test facilitys but its usually swap and see.
have to agree only use a genuine ford coil pack the cheap ones are a waste of money and fail constantly try this http://cgi.ebay.co.uk/COIL-PACK-IGNITION-Focus-Mondeo-fiesta-OE-FORD-not-COPY-/390059606163?pt=UK_CarsParts_Vehicles_CarParts_SM
It was indeed the coil pack and she's running sweetly again thank you all for you input.
