Dash Cam hard wire fuse
donscoth
 Share
59 minutes ago, Rizmo said:
The ground connection can be a little tricky.
On a Tesla it can be an absolute nightmare. Not sure why it should be a problem on a Puma 2023 model.
Link to comment
It's the accessibility to a particular bolt above the fuse box. A long reach box spanner or socket  is required. It's fiddly to access but with patience can be done.
  • Like 1
Link to comment
Just now, donscoth said:
Thought I might use a more accessible ground connection on the chassis. surely this would do the job.
Any chassis ground point will do. All you need is a point to be able to connect the dashcam negative lead.
Link to comment
I suggested the bolt above the fuse box as when the cover is replaced everything is out of sight. Of course any bolt will do as long as it's grounded.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
